Help with Export to CAD
5650
9
01-11-2017 01:39 PM
DawidB_1
In this script works clip to layer, but not work Export to Cad. I dont know how to do that, layer which have been clip goes to export to CAD
import arcpy
import os
arcpy.env.workspace = arcpy.GetParameterAsText(0)
obszar = arcpy.GetParameterAsText(1)
out = arcpy.GetParameterAsText(2)
try:
datasetList = arcpy.ListFeatureClasses()
for dataset in datasetList:
featureClassName = arcpy.ValidateTableName(dataset, out)
outFeatureClass = os.path.join(out, featureClassName)
if dataset != os.path.basename(obszar):
arcpy.Clip_analysis(dataset, obszar, outFeatureClass, "")
except:
print arcpy.GetMessages()
Nowy = arcpy.GetParameterAsText(3)
try:
datasetList2 = arcpy.ListFeatureClasses()
for dataset2 in datasetList2:
arcpy.ExportCAD_conversion(dataset2, "DWG_R2010", Nowy, "Ignore_Filenames_in_Tables", "Overwrite_Existing_Files", "")
except:
ClintonDow1
In this case it is probably easier to use the result from the Clip rather than ListFeatureClasses() to find the input dataset for ExportCAD. For example:
result = arcpy.Clip_analysis('input_fc', 'roads', 'output_fc')
result_cad = arcpy.ExportCAD_conversion(result, 'DWG_R2010', 'result_cad.dwg')
result_cad
<Result 'C:\\Users\\user\\Documents\\ArcGIS\\Projects\\MyProject4\\result_cad.dwg'>‍‍‍‍
In your case if the workspace and location of outFeatureClass are different then it will not find the result from Clip_analysis() when using ListFeatureClasses()
DawidB_1
Thank you for the remark! I appreciate it.
I removed the second "try" and "except", but it still does not return my result in dwg format. I do not know how to use a "result" so that my whole clip's passage could be. Could you show me how to edit the code? In the Annex toolbox with this tool.
import arcpy
import os
try:
            result = arcpy.Clip_analysis(dataset, obszar, outFeatureClass, "")
            result_cad = arcpy.ExportCAD_conversion(result, "DWG_R2010", 'result_cad.dwg')
except:
LukeWebb
What happends if you try to do it using the path you passed in instead of a result object:
We are obviously only expecting 1 CAD drawing to be output, as it will crash / overwrite it as we are saving it to the same path each time.  e.g.
arcpy.GetParameterAsText(0) + "\\"+ "result_cad.dwg"
import arcpy
import os
try:
            arcpy.ExportCAD_conversion(outFeatureClass, "DWG_R2010", 'result_cad.dwg')
except:
DawidB_1
The point is that I would like to have all the layers that will be clip, have been exported to the CAD file. After opening it in AutoCAD layers are all those clip .shp.
It was noticed that the code above cut me only the first 2 layers and creates a CAD file in the folder input, but only 1 clip shp.
LukeWebb
As I said, if you look at the errors the code will output, you should see it says:
"Output dataset already exists" as part of your
except:
As you have the try, except outside the loop, what happens is:
Clip 1st layer
Export first layer to CAD
Clip 2nd layer
Crash as output New.DWG already exists (You have this message being printed..)
Then, it exits the try except loop so stops processing.
Here I have given each CAD a unique name, and moved the try except so that it does not stop ALL processing when it crashes. (Just skip the current dataset)
index = 0
    index +=1
        try:
            output_CAD_name = 'CAD_' + str(index) + '_New.Dwg'
            arcpy.ExportCAD_conversion(outFeatureClass, "DWG_R2010", output_CAD_name)
        except:
DawidB_1
Unluckily after using your solution the tool clips layers, but doesnt export anything to CAD. Maybe there is some misprint in your code?
LukeWebb
Just to be sure, did you refresh the "Input" folder in catalog?
As we are not providing a workspace for the CAD outputs, the CAD drawings should be going into the arcpy.env.workspace you set, which is your input folder (WSADOWY), and not the output folder you highlight in the image..
I did notice an indentation error under the "Except" statement which might cause issues.
DawidB_1
UPDATE!!! WORK!!!
I have tried many times and in the end it works. I do not know if I can do that all created CAD files are in one DWG?
LukeWebb
Hey, try this code and see if it works!:
__author__ = 'WebbL'
import arcpy, os
clip_outputs = []   # An Empty list where we will keep track of all our clip outputs
        try:
            #Remember this output for the export to CAD step step
            clip_outputs.append(outFeatureClass)
        except:
#Now we export to CAD
Cad_path = os.path.join(out, "CAD_Output.DWG")
arcpy.ExportCAD_conversion(clip_outputs, "DWG_R2010", Cad_path)
