Hello I don't understand with programe to show "ImportError : No modle named ephem"
3550
11-08-2014 11:58 PM
JetsadaManussa
Hello
I don't understand with programe to show "ImportError : No modle named ephem" and how solution this programe
XanderBakker
Esri Esteemed Contributor
ephem is a python module that doesn't come with ArcGIS:
pyephem 3.7.5.3 : Python Package Index
Welcome! — PyEphem home page
The SunSkyMap tool you are running assumes the module is installed. Try installing the module and run the tool again. I assume the tool should come with some sort of documentation on prerequisites.
Kind regards, Xander
DanPatterson_Retired
You have either failed to turn on an extension via customize, extensions through the arcmap interface or it hasn't been setup if running in a script.  I presume that module is to work with ephemeris in some sky? extension?  check the requirements of the extension or tool that you are using
XanderBakker
