GIS Pro - Python and Arcade Labeling
2419
11-16-2018 07:39 AM
ChrisGoessl
We are attempting to do a simple if/else statement for labeling on a project but keep coming up with an error. The code is as follows:
def FindLabel ([Name], [Type]):
   if [Type]= 'Church':
      return "Church"
   else:
      return "Not Church"
The error that we are getting is as follows:
Invalid Expression
Error 0 on line 0
   File "<string>", line 2
      if esri_1 = 'Church':
SyntaxError: invalid syntax
We also worked on arcade (New to us). Here is that code:
if DomainName($feature, 'Type' ="Church") {
return $feature.Name
else {
return "Not Church"
We get the following error:
Invalid Expression
Error on line 1
Open parenthesis expected.
Any help will be greatly appreciated!
Chris Goessl & Justin Fowler
City of Kettering
JakeSkinner
Esri Esteemed Contributor
Hi Chris,
For the python portion, when you check if something is equal to, you will want to specify two equal signs (==).  Ex:
   if [Type]== 'Church':
      return "Church"
   else:
      return "Not Church"‍‍‍‍‍
JakeSkinner
Hi Chris,
      return "Church"
   else:
ChrisGoessl
ohhhhhhh.... I completely FORGOT about that. That's what happens when you switch between four different computer languages.
