get active map from ArcGIS Pro project
6094
9
07-11-2024 08:28 AM
nadja
Acually, I found various posts to how to get the active map of the current ArcGIS Pro project. they all start with this:
aprx = arcpy.mp.ArcGISProject("CURRENT")
active_map = aprx.listMaps(aprx.activeMap.name)[0]
I always get the exception "CURRENT". I already tried "current", then I get the exception "current". any idea whats wrong or how to make it right?
DanPatterson
MVP Esteemed Contributor
See example 2, it needs to be run from an open project within Pro
ArcGISProject—ArcGIS Pro | Documentation
otherwise specify the project's full pathname
also don't forget
import arcpy
... sort of retired...
nadja
I have "import arcpy" and I copy-pasted the second example, but I still get Exception: CURRENT. Any idea why?
what means "sort of retired"?
HaydenWelch
MVP Regular Contributor
The second line is actually redundant as the activeMap parameter returns a map object, and the listMaps(name)[0] is just getting the same map object you're feeding into it.
TonyAlmeida
import arcpy
# Get the current project
# Get the active map
map = aprx.activeMap
# Print active map.
print("Active Map:", map.name)
or
import arcpy
# print active map.
print("Active Map:", active_map.name)
HaydenWelch
Be careful overwriting builtins like 'map' with variable names, this can have unintended side effects if you have a long script and forget you did it.
If you absolutely have to use a built-in, try and mask it as an instance parameter so it's shielded by "self."/"instance." or if you need it in a larger scope, prefix it with an '_' ("_map")
nadja
if I understand you correctly, you would recommend the second line to be this:
HaydenWelch
You can simplify that by just saying:
_map = aprx.activeMap
As the activeMap attribute of an ArcGISProject object is a Map object (same as what's returned by listMaps)
If you keep getting the error, it means your project either doesn't have an active map, or your project is not open ("CURRENT" only works with *open* project files). If you need to do this on projects that are closed, you'll need to replace "CURRENT" with a full path to the .aprx file and replace .activeMap with either .listMaps()[0] for the first map in the project file (by order in contents). Or .listMaps('<mapName>')[0] for the first map that matches the '<mapName>' string.
Note: I prefixed your map variable with '_' for the reasons stated in my above comment. Shadowing builtin functions can have unintended side effects if you're doing it in the wrong scope. If you were to call 'map()' now it would raise a 'arcgis.Map object not Callable' error.
nadja
Thanks, but I still get the same error message 😞
mody_buchbinder
I always use
map1 = aprx.activeMap
You should try to open a project using full path (of different aprx then the one you are open with), just for checking.
Are other arcpy command works?
Note that if you open a project by path you do not always have activeMap
