Geopandas to PostGIS to ESRI?
1756
05-14-2021 01:05 PM
SamuelStroebel
Hello, I apologize if this is in the wrong place, what I am trying to accomplish is load data via database connection from a PostGIS table.  In testing, I can use geopandas to export a load data from a shapefile and export it to a table in a PostgreSQL database. When I connect to that database via an esri product (catalog, pro, ect.) It will load the geometry in preview, but the table is blank. I have no problems if I use geopandas to write shapefile, and load the shapefile into the database via the PostGIS tool. I thought it could be a problem with a unique ID field, but I created a field titled 'FID' as the first column in the table.
DanPatterson
MVP Esteemed Contributor
What esri product are you using?
What version of python are you using?
Why do you have to use shapefiles and geopandas?
... sort of retired...
SamuelStroebel
Use arcmap/catlog, and arcgis pro, but prefer to do analysis using pandas when possible. The reason I was looking at geopandas is it has easy methods for exporting and reading postGIS tables. I am running an second install of python from anaconda (not running geopandas on the ESRI install) python 3.8.5.
