Geocode Addresses Runs Fine in Pro But Fails With arcpy
1867
01-25-2022 11:33 AM
MichaelMorisette
Hello
I've been attempting to automate geocoding our address points to our street centerlines to tie some of the attribution together.
I have Geocoder setup that works fine in Pro (screenshot of it successfully running attached), but crashes when called via a Python script using the same parameters and running on the same machine.  Any thoughts as to why I'm getting this behavior?
I'm running ArcGIS Pro 2.8.2.
Here is the code:
from arcpy.geocoding import GeocodeAddresses
field_map = "'FULLADD' SingleLine VISIBLE NONE"
GeocodeAddresses(f"{GDB_PATH}/AddressToGeocode3",
                 ADDR_LOC,
                 field_map,
                 f"{GDB_PATH}/AddressToGeocode3_GeocodeAdd8")
GDB_PATH is the same path used by my Pro project
ADDR_LOC is the same locator path used in the Pro project
Here is the error message returned:
  File "<pyshell#8>", line 4, in <module>
    r"G:\GIS2\Staff\MikeM\Projects\SDE Maintenance\SDE Maintenance.gdb\AddressToGeocode3_GeocodeAdd8")
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geocoding.py", line 519, in GeocodeAddresses
    raise e
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geocoding.py", line 516, in GeocodeAddresses
    retval = convertArcObjectToPythonObject(gp.GeocodeAddresses_geocoding(*gp_fixargs((in_table, address_locator, in_address_fields, out_feature_class, out_relationship_type, country, location_type, category, output_fields), True)))
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 000010: Geocode addresses failed.
Failed to execute (GeocodeAddresses).
JayantaPoddar
Check if a similar script works for you? Please define full pathnames, wherever required.
import arcpy
arcpy.env.workspace = r"C:\Geocoding\locator\addresses.gdb" #Path of default geodatabase where the table and output FC is stored
# Set local variables
table = "AddressToGeocode3"
locator = r"C:\Geocoding\locator\AddressToCenterline.loc" #Full pathname of locator
geocode_result = "AddressToGeocode3_GeocodeAdd7"
arcpy.GeocodeAddresses_geocoding(table, locator,
                                 field_map, geocode_result)
I assume the locator file is saved in a basic folder, in which case you could define the full pathname of the locator file.
Think Location
MichaelVolz
Esteemed Contributor
Can you try adding print statements to see if your variables for paths are populating correctly?
DanPatterson
MVP Esteemed Contributor
For what its worth don't mix f-strings with unix path formation, use rf-strings to make sure you get the correct path formation.
gdb_path = r"G:\GIS2\Staff\MikeM\Projects\SDE Maintenance\SDE Maintenance.gdb"
z = f"{gdb_path}/AddressToGeocode3"
z1 = f"{gdb_path}/AddressToGeocode3_GeocodeAdd8"
z
'G:\\GIS2\\Staff\\MikeM\\Projects\\SDE Maintenance\\SDE Maintenance.gdb/AddressToGeocode3'
z1
'G:\\GIS2\\Staff\\MikeM\\Projects\\SDE Maintenance\\SDE Maintenance.gdb/AddressToGeocode3_GeocodeAdd8'
z = rf"{gdb_path}\AddressToGeocode3"
z1 = rf"{gdb_path}\AddressToGeocode3_GeocodeAdd8"
z
'G:\\GIS2\\Staff\\MikeM\\Projects\\SDE Maintenance\\SDE Maintenance.gdb\\AddressToGeocode3'
z1
'G:\\GIS2\\Staff\\MikeM\\Projects\\SDE Maintenance\\SDE Maintenance.gdb\\AddressToGeocode3_GeocodeAdd8'
... sort of retired...
