put a tag in metadata
526
01-25-2022 07:21 AM
danielROUFFART1
hi!
i would like to add a subelement in a metadata so i use this script
import os
import sys
import xml.etree.ElementTree as ET
from xml.etree.ElementTree import Element
import arcpy
from arcpy import metadata as md
# Script arguments...
Source_Metadata = [arcpy.GetParameterAsText(0)]
# Local variables
#    new purpose text
resTitle1 = "PMMCU"
jason = "PMMCU"
def update_metadata(root):
    num_elements = 0
    for child in root:
        print(child.tag, child.attrib)
    dataIdInfoEls = root.findall("./eainfo")
    for element in dataIdInfoEls:
        if element.text is not None:
            newCreditEl = ET.SubElement(element, "detailed")
            newCreditEl1 = ET.SubElement(newCreditEl, "attr")
            newCreditEl2 = SubElement(newCreditEl1, "attrdefs")
            newCreditEl2.text = resTitle1
            num_elements += 1
    return num_elements
but now my script don't work
do you know why that's don't work?
