Flipping Lines
1857
06-24-2011 06:21 AM
ManojBanga
Hi all!
I am looking for a python script which can flip all the lines in one direction.
Either north for vertical and east for horizontal lines.
Thanks
Manoj
ManojBanga
Hi All!
any solution to this please?
JakeSkinner
Esri Esteemed Contributor
If you have an ArcEditor license for ArcGIS 10 you can use the 'arcpy.FlipLine_edit' function to reverse the direction of your polyline data.
ManojBanga
Thanks Jake
but this is not what I am looking for, flip tool just reverse the current direction.
I need a script or method to flip all the lines in ONE DIRECTION.  It can be eaither North or East depending on if its closer to vertical or horizontal direction.
Thanks
DarrenWiens2
I can't write the actual script right now, but here's the method I would follow, in python:
read your lines into a search cursor
for each line in the cursor:
    get the first and last point coordinates
    calculate the change in x # first minus last, negative = W->E
    calculate the change in y # first minus last, negative = S->N
    if the absolute change in x is greater than the absolute change in y: # the line is in horizontal orientation
        if the change in x is positive: # line is E->W
            send line to new feature class to be flipped
            delete line from current feature class
    else: #the line is vertical
        if the change in y is positive: # the line is N->S
flip lines in new feature class
merge flipped lines back into original feature class
