model builder raster calculator converted to python script
1195
06-26-2011 04:50 AM
AliceDeschamps1
I exported this from a working model builder tool and working on modifying to make it work in python.  In the end I would like to be able the automatically rename the output => input + ST_DEV + enh.tif .
I am fairly new to Python so I am not there yet!  Python does not seam to recognize the map algebra from arcpy.gp.RasterCalculator_sa that was exported from Model Builder.   Therefore I decided to convert this part to straight python map algebra but I keep on getting errors for the code under # Process: Raster Calculator (1)
"RuntimeError: ERROR 000732: Input Raster: Dataset inRaster does not exist or is not supported."   This does not make sense to me since the inRaster is recognised in the previous 3 GetRasterProperties statements since the print statements are ouputting the right values?
Any suggestions on how to make this work??
# copy and past this at promt: 15May2011_HH_set_zero_8bit.tif 3 test.tif
# Import arcpy module
import arcpy
from arcpy import env
from arcpy.sa import *
import sys, string, os
# Set Geoprocessing environments
arcpy.env.workspace = "C:/Alice"
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Script arguments
inRaster = arcpy.GetParameterAsText(0)
No_STDEV = arcpy.GetParameterAsText(1)
Output_Enhanced_8bit_SAR_Image = arcpy.GetParameterAsText(2)
# Process: Get Raster Properties (2)
imageMin=arcpy.GetRasterProperties_management(inRaster, "MINIMUM")
print "Image MIN value=", imageMin
# Process: Get Raster Properties (3)
imageMean=arcpy.GetRasterProperties_management(inRaster, "MEAN")
print "Image MEAN value=", imageMean
imageSTDEV=arcpy.GetRasterProperties_management(inRaster, "STD")
print "Image STDEV value=", imageSTDEV
enhImage=((Raster("inRaster") - imageMin) / ((imageMean + No_STDEV * imageSTDEV) - imageMin)) * 255
# Process: Raster Calculator (2)
outCon= Con(enhImage, enhImage, 255, "VALUE < 255")
# Process: Copy Raster
arcpy.CopyRaster_management(outCon, Output_Enhanced_8bit_SAR_Image, "", "", "", "NONE", "NONE", "8_BIT_UNSIGNED")
AliceDeschamps1
Fixed the error mentioned above with the code below.  Of course, I get a new error for same line ;(   Either the syntax or that .save?
# Process: linear stretch with right tail trim
enhImage = ((Raster(inRaster) - imageMin) / ((imageMean + No_STDEV * imageSTDEV) - imageMin)) * 255
enhImage.save("enhImage")
LoganPugh
Take care not to quote variable names as quoting indicates it's a string, not a variable.
Also, not a big deal since there is no indentation in this script, but it makes it easier to read when you use the CODE tags (#) icon on the formatting toolbar above the message body box on your code to preserve indentation, which is significant in Python.
AliceDeschamps1
Yes, thanks.  Its slowly coming back to me.   Now the new errors seam to be caused by a mix of integers, floats & string in my map algebra expression.  My inRaster & imageMin are integers while my imageMean and imageSTDEV are floats but some of these variables are coming in as stings too.  It a matter of getting the right conversions going now and I think is should work!
