Finding out if layer exsists in file geodatabase
2484
10-17-2011 10:57 AM
ScottBlankenbeckler
Is there an easy way to check if a layer exsist in a file geodatabase with python?
I need to run multiple processes on a series of layers and as some point the layer may not exsists (i.e. no file created) but need to check before running the next process.
Example:  First step is geocoding but if table contains no data I skip the geocode. However, the next step is to add fields to the layer but if it does not exsist I need to skip this step.
I know how to find a file on the system
if os.path.exists(filepath\name):
but not sure about stuff within geodatabase
MathewCoyle
Honored Contributor
