Sample Code: Embedding gp tools or data inside of a python addin file
3560
10-07-2011 02:39 AM
MoragHawkins
Hi All
Not too sure if this will interest anyone, if it is supported etc, but it is possible to embed gp tools (.tbx or .pyt) as part of the addin itself, so that if you have a python addin you do not have to distribute the gp tools separately. This would be useful if you have a complex gp tool that cannot be achieved easily through an addin itself e.g. it has lots of parameters or a value table etc.
This would all apply to data if you wanted to distribute a fgdb or something inside of your addin, or an mxd, a lyr file etc etc.
1) Firstly, copy your .pyt or .tbx into the addins Install folder. If using a .tbx, make sure it is set to use relative paths.
2) In your addin py file, add
import os
relPath = os.path.dirname(__file__)
3) When the addin is created and installed, all the files you included sit relative to the calling script. So, you can use this relPath setting to go grab your extra stuff, e.g. to launch an embedded gp tool, use
pythonaddins.GPToolDialog(relPath+r'\MyPythonToolbox.pyt', 'MyPyTool')
Aside - this has solved an issue I had raised in another thread around the lack of complex parameter setting in python addins, I can now embed a python toolbox with all its parameter functionality as my 'Options dialog' in the addin, writing the changes back to an xml file when user clicks ok in the gp Options dialog. Addin then reads from this xml.
ChrisFox3
Hi Morag,
What you have described below is definetly supported and acutally makes a lot of sense for your workflow. The other cool thing is in your script tool you could code in the validation code to pull values from the xml so that the users inputs persists between sessions allowing them to just change one value at a time if they wish. Nice post.
KevinBell
I like the sound of this, but I'm not exactly clear where this goes:
---This should definitely be a presentation at the UC, and/or a white paper with a working sample!
MoragHawkins
Please find attached a quick and dirty example.
OptionsDialog.esriaddin - a sample addin
arcpyXmlHelper.zip - a zipfile containing a set of instructions and sample options toolbox.
I have tried to do a helper module for those not familiar with reading/writing xml, so you can for example call the following from within your python addin to read parameters.
getXmlParameterAsText(0)
or
getXmlParameterAsValue(0)
or
getXmlParamterInfo()
or
getXmlAttributeAsText(0,'datatype')
Everything is detailed in the .zip file -> installation_instructions.txt
MoragHawkins
in the button or menus onclick function
def onClick(self):
        pythonaddins.GPToolDialog(relPath+r'\OptionsDialog.tbx', 'SaveOptions')
