Field calculator, sum of field.
20786
10
01-07-2015 10:22 AM
BenjaminMittler
I am having a bit of a problem with what seems like should be a simple field calculator expression. I have a table with about 50 rows and a column with acres for each row. I've created a new column called Percent_Acres (Double) and im looking to calculate the percent each feature makes up of the total acres.
I want an expression equal to this Percent_Acres = Acres / Total Acres.
Normally this would be easy to do and i would just look up the field statistics for the sum. However this calculation is part of a model that will be automated so i need an expression that will automatically calculate the columns sum while in the field calculator.
It appears that i am having a problem with iterating through each row to add up to the total. I have tried numerous expressions and each time i get the same result telling me that "typeerror float object is not iterable"
Any advise on this topic would be greatly appreciated
Thanks, Ben
JuneSkeeter
This is absurd ... is this really the easiest way to sum a field in the field calculator?  Why doesn't something like this work:
!Shape_Area!/!Shape_Area!.sum()
