Field Calculator Expression Arcpy
7888
11
01-27-2016 03:25 PM
HOWARDWILLIAMS
So I am writing a script to perform a Union on multiple feature data sets.
Feature data sets:  R1ADS1999Damage, R1ADS2000Damage.....R1ADS2013Damage  (these are all polygon feature classes with the same attribute fields years 1999-2013)
I need to join the first (1999) year to the next year, naming the joined feature class R1ADS1999-2000Damage, and then add three new fields called: TPA_1999_2000; Acres_1999_2000 and; NoTrees_1999_2000.  Each new field is calculated with a unique (field calculator) expression.  I will provide these calculations in a moment.  Once the fields are added and the values calculated the newly created unioned feature class, R1ADS1999-2000Damage, needs to be unioned to R1ADS2001Damage, the next chronological year. Fields called  TPA_1999_2001; Acres_1999_2001 and; NoTrees_1999_2001  need to be added and calculated.  This pattern continues until the final year 2013.
TPA_1999_2000 = Is the sum of field TPA_1999 + TPA_2000, after the next union the TPA_1999_2001= TPA_1999_2000+TPA_2001 this pattern continues for after all unions.
Acres_1999_2000= Is a recalculation of geometry after the union, in Acres. This is the same for all subsequent unions.
No_Trees_1999_2000= Is TPA_1999_2000 * Acres_1999_2000. After the next union the NoTrees_1999_2001= TPA_1999_2001*Acres1999_2001
I have managed to get the union and adding fields part of the script done, see below.  I got stuck on writing the Field Calculator expression for the TPA_1999_20XX.
It seems that I need an expression that sums all of the fields that begin with TPA_  something like
TPA_1999_2000= sum([!TPA_*!)   However this does not work.
So here is the code I have come up with so far until got stuck:
R1="R1ADS"
Dam="Damage"
years=['1999','2000', '2001', '2002', '2003', '2004', '2005', '2006', '2007', '2008', '2009', '2010', '2011', '2012', '2013']
fields=['TPA_','Acres_','NoTrees_']
RangeYear= ['1999_2000','1999_2001','1999_2002','1999_2003','1999_2004','1999_2005','1999_2006','1999_2007','1999_2008','1999_2009','1999_2010','1999_2011','1999_2012','1999_2013']
expression=['TPA_ expression', 'Acres_expression', 'NoTree_expession'] ### Note these are place holders for the correct expressions that I need help with.
arcpy.Union_analysis([R1+years[0]+Dam,R1+years[1]+Dam],R1+years[0]+"_"+years[1]+Dam)
for i in range(0,13) :
  arcpy.Union_analysis([R1+years[0]+"_"+years[i+1]+Dam,R1+years[i+2]+Dam],R1+years[0]+"_"+years[i+2]+Dam)
  print years[0]+'_'+years[i+2]+" union done"
         for j in range(0,3):
                 arcpy.AddField_management(R1+years[0]+'_'+years[i+2]+Dam, fields+RangeYear, "FLOAT","","","")
                 arcpy.CalculateField_Management(R1+years[0]+'_'+years[i+2]+Dam, fields+RangeYear,expression)
I would appreciate any help you can give, please do not worry about insulting me I am new to programming.
DanPatterson_Retired
Xander... Yes good... there is a variant that interweaves two lists or portions of a single list too.
>>> years = ['1999', '2000', '2001', '2002', '2003', '2004', '2005', '2006','2007', '2008']
>>> text = [z[0] +"_"+ pair[1] for z in zip(years[:-1], years[1:])]
>>> text
['1999_2000', '2000_2001', '2001_2002', '2002_2003', '2003_2004', '2004_2005', '2005_2006', '2006_2007', '2007_2008']
OR
>>> text = ["{}_{}".format(z[0], z[1]) for z in zip(years[:-1], years[1:])]
but I do like using the new formatting options so that you don't have to care about casting between strings or text if you don't want to.
HOWARDWILLIAMS
Thanks, it got weird when I cut and pasted it from my IDE, sorry about that.  I will fix it up tomorrow.
Cheers
Howard
