Field calculate sequential letters
9029
8
12-13-2017 02:20 PM
RIMNTIR
Hello,
I am trying to figure out how I can use the field calculator with python to calculate sequential letters. For example, I would like "A,B,C,D....Z, AA,AB, AC...".  I did find a code that works just fine in a regular python environment but I am having a hard time incorporating it on the field calculator.
excel - How to make a continuous alphabetic list python (from a-z then from aa, ab, ac etc) - Stack ...
I tried using this as the code block:
from string import ascii_lowercase
  import itertools
def iter_all_strings():
   size = 1
   while True:
      for s in itertools.product(ascii_lowercase, repeat=size):
            yield "".join(s)
        size +=1
and  "iter_all_strings()" as the expression in the field calculator but it just gives me null values.
Any help would be much appreciated, thank you.
RandyBurton
And using your code, this would go in the code block:
import itertools
    size = 1
    while True:
            yield "".join(s)
        size +=1
s = iter_all_strings()
The expression would be:
s.next()
The generator needs to be set up in the code block.
DanPatterson_Retired
how big is the file? aka does it cut off at ZZ?  If it is short, it might just be easier to generate the list, then slice it based on a unique ID field (perhaps OBJECTID -1 )
Rhys-Donoghue
This is fairly straightforward.  Sorry, I don't have the time to write the code for you but if you check the end of this video I did, you can see how I used Python for creating the letters: https://www.youtube.com/watch?v=QA0iFlP0V3Y - I needed A1 to AA1 to AAA1, etc. If you're really stuck and still can't work it out, let me know and I can create a working example for you.
RandyBurton
Using a modified number base function, try this in the code block:
i = -1
def letterString():
    global i
    i += 1
    return toStr(i,26)
def toStr(n,base):
    convertString = "ABCDEFGHIJKLMNOPQRSTUVWXYZ"
    if n < base:
        return convertString[n]
    else:
        return toStr(n//base-1,base) + convertString[n%base]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
and this for the expression
letterString()
Basically, you will need to set up a global variable in your code block and increment it each time your function is called.
RandyBurton
import itertools
    size = 1
    while True:
            yield "".join(s)
        size +=1
s.next()
RIMNTIR
Randy,
Thank you very much, problem solved!
JoshuaBixby
MVP Esteemed Contributor
Expression:  next(values)
Expression Type:  PYTHON_9.3
Code Block:
from itertools import count, product
cnt = count(1)
values = ("".join(v)
          for c in cnt
          for v in product(ascii_lowercase, repeat=c))
TedKowal
Honored Contributor
from string import ascii_uppercase
import itertools
    size = 1
    while True:
        for s in itertools.product(ascii_uppercase, repeat=size):
            yield "".join(s)
        size +=1
for s in itertools.islice(iter_all_strings(), 54):
    print s
Just save your stopping point in line 11 (number of iterations you want  54... I believe is "BB"
RandyBurton
A clean, efficient solution.  Thanks for sharing bixb0012‌.
