FeatureClass to FeatureClass error
2533
01-05-2021 05:06 AM
CliveSwan
Greetings,
I can return and loop through a list of Features that I want to export to a file gdb.
I can't add the  gdb + Feature as a variable to export.
It fails in the arcpy.FeatureClassToFeatureClass_conversion(Features, outLocation, outFeatures) section.
I would appreciate any pointers, and/or links to help resolve this.
import arcpy
import arcgis
from arcgis.gis import *
from arcgis.gis import GIS
from arcgis.features import FeatureLayer
from arcgis.features import FeatureLayerCollection
import pandas as pd
## SET Parameters
arcpy.env.orverwriteOutput = True
arcpy.env.workspace = r"D:\Users\user\Documents\ArcGIS\Projects\Databases\SDE.sde"
datasets = arcpy.ListDatasets(feature_type='feature')
datasets = [''] + datasets if datasets is not None else []
print("START")
## output file
outLocation = (r"W:\My Documents\user\ENV.gdb\ENV")
inFeatures = ""
outFeatures = inFeatures
#### EXPORT DATA
for ds in datasets:
    for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
        new_name = fc.split('.')[-1]
        #print(new_name)
        Features = ([new_name])
        print(inFeatures)
The arcpy error message
RuntimeError                              Traceback (most recent call last)
<ipython-input-13-f520ea9e3f4b> in <module>
     38         Features = ([new_name])
     39         print(inFeatures)
---> 40         arcpy.FeatureClassToFeatureClass_conversion(Features, outLocation, outFeatures)
     41
     42             # outFile.close
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py in FeatureClassToFeatureClass(in_features, out_path, out_name, where_clause, field_mapping, config_keyword)
   2098         return retval
   2099     except Exception as e:
-> 2100         raise e
   2101
   2102 @gptooldoc('FeatureClassToGeodatabase_conversion', None)
   2095     from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
   2096     try:
-> 2097         retval = convertArcObjectToPythonObject(gp.FeatureClassToFeatureClass_conversion(*gp_fixargs((in_features, out_path, out_name, where_clause, field_mapping, config_keyword), True)))
   2098         return retval
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py in <lambda>(*args)
    509         val = getattr(self._gp, attr)
    510         if callable(val):
--> 511             return lambda *args: val(*gp_fixargs(args, True))
    512         else:
    513             return convertArcObjectToPythonObject(val)
RuntimeError: Object: Error in executing tool
Regards,
Clive
BlakeTerhune
There's a lot going on in your code that is either redundant or slightly off. I recommend familiarizing yourself with the syntax of FeatureClassToFeatureClass_conversion()
Here's a simplified version. See if this runs and does what you want.
import arcpy
sde_workspace = r"D:\Users\user\Documents\ArcGIS\Projects\Databases\SDE.sde"
env_gdb = r"W:\My Documents\user\ENV.gdb\ENV"
print("START")
for ds in arcpy.ListDatasets(feature_type="Feature"):
    new_name = ds.split(".")[-1]
    print("Copying {}".format(new_name))
    arcpy.FeatureClassToFeatureClass_conversion(ds, outLocation, new_name)
BlakeTerhune
import arcpy
print("START")
