Extracting rasters from NetCDF files based on time dimension
7108
13
09-11-2016 10:18 PM
ShouvikJha
I have single netCDF file which contain monthly data for different year. (Format of date e.g 2001-1-1, 2001-2-1, 2001-3-1…….2002-12-1...............2015-0-1......2015-12-1).
Here-with i have attached a snapshot of data format from Arc GIS multidimension tool
I trying to extract each month raster for selected year (e.g only 2002). Save it as 01-2002, 02-2002, 03-2002…..12-2002.
I appreciate any help you can provide on the crucial bottom code.
Here is what I have so far:
# Import system modules
import arcpy
from arcpy import env
from arcpy.sa import *
#Workspace
outLoc = r"D:\MODIS_NPP_02_15"
inNetCDF = r"D:\MODIS_NPP_02_15\NPP_2001_15.nc"
#Veriable
variable = "npp"
x_dimension = "lon"
y_dimension = "lat"
band_dimension = ""
dimension = "time"
valueSelectionMethod = "BY_VALUE"
nc_FP = arcpy.NetCDFFileProperties(inNetCDF)
nc_Dim = nc_FP.getDimensions()
for dimension in nc_Dim:
        if dimension == "time":
            top = nc_FP.getDimensionSize(dimension)
            for i in range(0, top):
                dimension_values = nc_FP.getDimensionValue(dimension, i)
                nowFile = str(dimension_values)
                nowFile = nowFile.translate(None, '/')
                # I needed only the years 2002
                if int(nowFile[-12]) > 6:
                    dv1 = ["time", dimension_values]
                    dimension_values = [dv1]
                    arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, x_dimension, y_dimension, nowFile, band_dimension, dimension_values, valueSelectionMethod)
                    print "success"
                    outname = outLoc + nowFile
                   arcpy.CopyRaster_management(nowFile, outname, +".tif","", "", "", "NONE", "NONE", "")
                else: print "DATA OUT OF RANGE"‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
ShouvikJha
Dan Patterson‌, I corrected the line by replace line no 4 suggested by you. Now i am getting following error massage. Error massage displaying output raster name can't be more than 13 character. So whats is the possible way to short the output raster name
Message     File Name     Line     Position
Traceback
    <module>     D:\Arc-GIS-Python-Script\NetCDF_RASTER_TIME_SERIES.py     39
    CopyRaster     C:\Program Files\ArcGIS\Desktop10.1\arcpy\arcpy\management.py     11034
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000472: Name of single band grid cannot have more than 13 characters
Failed to execute (CopyRaster).
DanPatterson_Retired
Yes... esri grids can't have filenames that long... the solution is to shorten what your have or make up a new name
>>> outFile = "abcdefghijklmnopqrstuvwxyz"
>>> outfile = "abcdefghijklmnNPP_2001_15"
>>> result = outLoc + "\\N" + outfile[-7:]
>>> result
'D:\\MODIS_NPP_02_15\\N2001_15'
>>> # or for slice/dice and replace all at once...
>>> result2 = outLoc + "\\N" + outfile[-7:].replace("200","0")
>>> result2
'D:\\MODIS_NPP_02_15\\N01_15'
ShouvikJha
i renamed the input name as well as folder name to make it short, but error still persist . PyScripter getting crash
Traceback
    __call__     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\netref.py     196
    syncreq     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\netref.py     71
    sync_request     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\protocol.py     431
    serve     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\protocol.py     379
    _recv     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\protocol.py     337
    recv     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\channel.py     50
    read     E:\Geo_Softwares\PyScripter\PyScripter\Lib\rpyc.zip\rpyc\core\stream.py     166
exceptions.EOFError: [Errno 10054] An existing connection was forcibly closed by the remote host
It is the folder name and the file name that is more important.  And rpyc.zip... how does that come into play?
