Extract Feature Attachments
28366
32
10-24-2013 01:13 AM
Ranga_Tolapi
"Feature attachments" is the new feature from ArcGIS 10 on wards. How to extract feature attachments and save to disk using Python?
TrilliumLevine1
I figured out the problem with the expression -- extra quotes are needed around the curly braces.  Line 28 (or 35 in your snippet) should therefore read:
expression = arcpy.AddFieldDelimiters(fc, fldOID) + " = '{0}'".format(relOID)
XanderBakker
Esri Esteemed Contributor
Yeah that makes sense. Glad you figured it out.
BillSpiking__GISP
Hi Xander!
I know this thread is quite old, but I thought I'd give it a try anyway.  I'm trying to implement your "QueryRelated Data" function in 10.3 and I'm getting the runtime errors below.
Runtime error
  File "<string>", line 36, in <module>
  File "<string>", line 17, in main
RuntimeError: cannot open 'C:\PhotoLog\AGO\gdb\GPO_PhotoLog.gdb\Photo_Video_Documentation_ATTACH'
Has anything changed with 10.3 that would cause these errors?  I've provided my code as well.  Any help would be greatly appreciated!
def main():
    global arcpy
    import arcpy, os
    # fixed settings
    fldBLOB = 'DATA'
    fldAttName = 'ATT_NAME'
    fldRelGID = 'REL_GLOBALID'
    # your settings (edit these)
     ## related feature class
    fc = r"C:\PhotoLog\AGO\gdb\GPO_PhotoLog.gdb\Photo_Video_Documentation"
    ## attachment table
    tbl = r"C:\PhotoLog\AGO\gdb\GPO_PhotoLog.gdb\Photo_Video_Documentation_ATTACH"
    fldRelatedInfo = 'CreationDate' # should be valid column in FC
    with arcpy.da.SearchCursor(tbl,[fldBLOB,fldAttName,fldRelGID]) as cursor:
        for row in cursor:
            binaryRep = row[0]
            fileName = row[1]
            relGID = row[2]
            # access related information
            myRelatedInfo = QueryRelatedData(fc, fldRelatedInfo, relGID)
            print myRelatedInfo
def QueryRelatedData(fc, fldRelatedInfo, relGID):
    fldGID = 'GlobalID'
    expression = arcpy.AddFieldDelimiters(fc, fldGID) + " = '{0}'".format(relGID)
    with arcpy.da.SearchCursor(fc, (fldGID, fldRelatedInfo), where_clause=expression) as cursor:
        for row in cursor:
            return row[1]
            break
        del row
if __name__ == '__main__':
    main()
XanderBakker
Hi William Spiking ,
Just did a test with 10.3 and the code (stil) works. I do notice that in the name of the attachment table you have a single underscore:
This should be a double underscore __ATTACH:
'C:\PhotoLog\AGO\gdb\GPO_PhotoLog.gdb\Photo_Video_Documentation__ATTACH'
Please try again with that little correction.
BillSpiking__GISP
That did the trick!  Can't believe I missed that!
Thank you!
XanderBakker
It is a common mistake as it happened to me too. Due to this kind of errors, I normally tend to copy the path from the source tab of the layer or table to be sure to have the right path and name of the object class,
XanderBakker
Would you be able to extend your code in python to be able to access  images already stored as a BLOB field in SQL Server 2012 (non-GIS) as  attachments without having to copy the images into ESRI feature classes  thus eliminating data duplication of attachment files?
Hi Michael,
Could you explain this a little more? Do you have images stored in SQL Server 2012, and you want to use them as attachment, without the need to convert them to an Esri attachment table? If that's the case, I don't think ArcGIS will recognize them as attachments.
If you would like to extract the BLOB attachments stored in SQL Server 2012 by code, I think you should be able to do so. If the SQL Server 2012 table can be accessed by ArcGIS, you can loop through it and extract the attachments (like in the code, save it to disk).
After saving the files to disk, I guess you can use "Generate Attachment Match Table (Data Management)" and Add the attachments (which would duplicate or "triplicate" the data). More on this in the Help topic "Working with the Attachments geoprocessing tools".
Not sure, if this is the answer you are looking for.
Kind regards,
Xander
MichaelVolz
I'm not a Database Administrator (DBA), but the DBAs at my organization are always trying to minimize unnecessary data duplication which seems what is occurring with the attachments if you already have the data stored in another format other than feature classes that recognize attachments.
Don't you think it would be more efficient if attachments could just be created in the native format that the original attachment files were stored in?
XanderBakker
Hi Michael,
The DBAs (and you) are right; data duplication creates a lot of extra work (apart from the additional data storage). Maybe in the future we'll see some extra functionality in ArcGIS allowing us to create attachments in the form of "hyperlinks" to existing data.
I see two ideas that kinda want the same as you're proposing:
Geodatabase Attachments for large organizations
Geodatabase Attachments Storage Location Option
I think we should promote those ideas.
Kind regards,
Xander
MichaelVolz
I had already promoted both of these ideas weeks ago.  Now I am hoping that other GIS users will join the bandwagon so that ESRI see the need for this additional functionality.
