exportToSDDraft Error connecting to server
2679
09-18-2022 05:47 AM
arahman_mdmajid
I am trying to create an sddraft file for publishing a arcgis pro project to our portal.
Below is my code.
sddraft_filename = "service.sddraft"
sddraft_output_filename = os.path.join(draftsOutputDir, sddraft_filename)
service_draft = m.getWebLayerSharingDraft("FEDERATED_SERVER", "MAP_IMAGE" , service)
service_draft.summary = "My Summary"
service_draft.tags = "My Tags"
service_draft.description = "My Description"
service_draft.credits = "My Credits"
service_draft.useLimitations = "My Use Limitations"
service_draft.overwriteExistingService = True
service_draft.allowExporting = True
service_draft.portalFolder = "User_Folder"
service_draft.federatedServerUrl = "https://MyFederatedServer.esri.com:6443/arcgis"
service_draft.copyDataToServer = False
service_draft.serverFolder = "Server_Folder"
# Create Service Definition Draft file
service_draft.exportToSDDraft(sddraft_output_filename)
Right when it execute the exportToSDDraft function, its throwing the following error.
Message=Error connecting to server: https://MyFederatedServer.esri.com:6443/arcgis
Source=C:\Users\user\AppData\Local\Programs\ArcGIS\Pro\Resources\ArcPy\arcpy\sharing.py
StackTrace:
File "C:\Users\user\AppData\Local\Programs\ArcGIS\Pro\Resources\ArcPy\arcpy\sharing.py", line 68, in exportToSDDraft
    return _convertArcObjectToPythonObject(self._arc_object.exportToSDDraft(out_sddraft,self))
File "C:\Users\user\source\repos\PythonApplication1\PythonApplication1\PythonApplication1.py", line 118, in mapAndFeatureServicePublish
File "C:\Users\user\source\repos\PythonApplication1\PythonApplication1\PythonApplication1.py", line 162, in <module> (Current frame)
    mapAndFeatureServicePublish(m, draftsOutputDir, row, featureAccess = row['FEATURE ACCESS? (Y/N)'])
The federated url is correct as I copied it from the portal admin and in the list of federated server url.
Also I am able to connect to via normal url and create connection to it also.
Kindly advise.
Abdur Rahman
GIS Developer
by Anonymous User
Not applicable
If your server is set with an admin login for port 6443, it could be failing on not getting a login token.  Try using the server connection file (ends with .ags) for the connection instead of the url.
target_server_connection = r"C:\Project\gisserver.ags.esri.com (publisher).ags"
Or, you will have to generate a token and pass it with your url.
service_url = f"https://MyFederatedServer.esri.com:6443/arcgis/services/.../...?token={token}&f=json"
