I try to export a PDF with a scheduled task that runs in an arcgis server's server.
The ExportToPDF line of code crashes without any error with the python from ArcGIS Server, but works great with the python from ArcGIS Pro in other environments...
Here is a simple code test I made, it's crashing in the last line :
import arcpy
aprx = arcpy.mp.ArcGISProject(r"D:\path...\exportToPDF.aprx")
m = aprx.listMaps("Map")[0]
layout ="Test"
lyt = aprx.listLayouts(layout)[0]
mf = lyt.listElements("mapframe_element", "WEBMAP_MAP_FRAME")[0]
extent = arcpy.Extent(446998.96875, 214866.71875, 446579.875, 215163.046875)
mf.camera.setExtent(extent)
m.defaultCamera = mf.camera
lyt.exportToPDF(out_pdf=r"D:\path...\out.pdf")
Working with Pro 3.3
Not working with Server 11.3
Any idea ?
I found the solution.
I tried to install ArcGIS Pro on the server to see if there was any difference, and the setup required installing Microsoft Edge WebView2 RuntimeInstaller X64.
Finally, it now works with the ArcGIS Server's python and I think it is the installation of the webview and not Pro that solved it.
I think ArcGIS Enterprise Setup should also require this webview to be installed...
the path exists? (line 10) and you can write to it?
Same python version? and api for python version?
Here is a screenshot with a cloned environment from Pro, version 3.11.8 and PDF is written :
and here with Server's python, same version and nothing happens :
I also tried
try:
print("try")
mf.exportToPDF(out_pdf=r"C:\Temp\out.pdf")
except exception as e:
print(e)
but no exception is returned
Tech Support is your best option.
related post
Solved: Python Script succeeds in IDLE(ArcGIS Pro 2.9.0) b... - Esri Community
so there are documented issues along this vein
ArcGIS Pro 3.3 system requirements—ArcGIS Pro | Documentation
there it is
WebView2 Runtime
Microsoft Edge WebView2 Runtime version 117 or later is required. If it is not already installed on the machine, use the Evergreen Bootstrapper or Evergreen Standalone Installer from Microsoft.
Note:
A per-machine installation (the default) of ArcGIS Pro requires a per-machine installation of WebView2 Runtime. To do this, right-click the WebView2 installer and click Run as administrator.
Thanks, Dan,
WebView2 is not part of the ArcGIS Enterprise or Server requirements (https://enterprise.arcgis.com/en/system-requirements/latest/windows/arcgis-server-system-requirement...)
but I understand that any arcpy function using an APRX will need the requirements of ArcGIS Pro and not only ArcGIS Server.
