Export to PDF and Save a Copy saves to the wrong folder
4853
08-24-2011 11:23 AM
deleted-user-MS0lE1F_0-sy
I am using parameters to save an mxd and export a pdf.  Tried using both workspace and folder.  Problem is that it gets saved to one folder down from the one I tell it two.  It also adds the name of the folder I tell I wanted it in at the front of the mxd and pdf.  What am I doing wrong.  This is my very first script!
# 8/16/2011
# Aerial Map Script
# import arcpy.
import arcpy.mapping
# Define Map Document location.
mxd = arcpy.mapping.MapDocument("C:/GIS/Script1/maps/Template_Aerial_Imagery4.mxd")
# Define Data Frame.
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
# Add a Parameter for Locating the Layer you want to Add and Add the Layer
Layer = arcpy.GetParameterAsText(0)
addLayer = arcpy.mapping.Layer(Layer)
arcpy.mapping.AddLayer(df,addLayer,"TOP")
# Select Layer, Zoom to Layer.
arcpy.SelectLayerByAttribute_management(addLayer,"NEW_SELECTION")
df.zoomToSelectedFeatures()
# Define scale of dataframe and set the reference scale.
df.scale = 2400
df.referenceScale = 2400
# Clear the Selection
arcpy.SelectLayerByAttribute_management(addLayer,"CLEAR_SELECTION")
# Change "Project Name (PN)" & "County, State (CS)" Text; Using Parameters
ALPname = arcpy.GetParameterAsText(1)
elPN = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT","Project Name")[0]
elPN.text = ALPname
CSname = arcpy.GetParameterAsText(2)
elCS = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT","County, State")[0]
elCS.text = CSname
# Refresh the Active View
arcpy.RefreshActiveView
# save mxd
ProjNum = arcpy.GetParameterAsText(3)
mxd.saveACopy(arcpy.GetParameterAsText(4) + ProjNum + "_Aerial_Imagery.mxd")
# Export to PDF
PDFloc = arcpy.GetParameterAsText(5)
arcpy.mapping.ExportToPDF(mxd,PDFloc + ProjNum + "_Aerial_Imagery.pdf")
# Clear the mxd from script lock
del mxd
_____________________________________________________________________________
Also I tried to trouble shoot the problem by exporting a random map in ArcMap using python command line and it althought the name of the file was correct it also saved it a folder down one in the list.
Example.
>>> import arcpy
>>> mxd = arcpy.mapping.MapDocument("CURRENT")
>>> arcpy.env.workspace = "C:\GIS\test\New_Folder"
>>> arcpy.mapping.ExportToPDF(mxd,"output.pdf")
It will export it to the test folder instead of the New_Folder folder.  ???
I got it figured out. In case someone else runs into this....I needed to put a "/" after the GetParameter.  I thought I had tried that, so simple.
AndrewKlimek
I'm having the same issue with my output file (a txt file in my case) getting outputted to the wrong folder in the directory path.  I have tried to follow Matthew's solution above to incorporate the "/" after the GetParameter, but I end up with syntax errors.  Could someone alter his code to show me where the "/" should be placed?  Thanks.
Without seeing the code and error it's hard to say.  Are you putting "/" for the rest of the path? If you use "\" you need to add the r at the beginning of the path."Y:/folder1/folder2/folder3/PARAMETER INPUT"      or    r"Y:\folder1\folder2\folder3\PARAMETER INPUT" .   Is your output setting of the parameter a text?
XanderBakker
Esri Esteemed Contributor
It would be better to use the os.path.join to create the path to the output file.
Example:
import os
my_folder = r"C:\aFolder\aSubFolder"
my_filename = "someFileName.ext"
print os.path.join(my_folder, my_filename)
... will yield this:
C:\aFolder\aSubFolder\someFileName.ext
And you can even do this:
import os
print os.path.join(my_folder, "anotherSubFolder", my_filename)
... which will yield this:
C:\aFolder\aSubFolder\anotherSubFolder\someFileName.ext
AndrewKlimek
Thank you Matthew and Xander.
Using the os.path.join worked like a charm.
