Export/import web map's json
2272
10-07-2022 04:58 PM
forestknutsen1
How do I export and then import a web map's json with python? I took a quick look at the GIS module... but I did not see the right call.
jcarlson
For exporting, use Item.get_data().
For importing? As @DanPatterson 's linked post mentions, you'll probably want to use the json module to make sure your JSON is formatted properly. To pass your modified JSON back to the map, just use Item.update(item_properties={'text':your_JSON_obj}).
- Josh Carlson
Kendall County GIS
DanPatterson
MVP Esteemed Contributor
related links using the json module
Solved: Can't create a valid Web Map from a JSON definitio... - Esri Community
... sort of retired...
jcarlson
- Josh Carlson
Kendall County GIS
forestknutsen1
@jcarlson thanks! that did the trick
