Evaluate Where Clause
2454
09-20-2017 07:43 AM
JoeBorgione
A new day, a new question...
Working with arcpy.da.SearchCursor, I can select features based on a given where statement.  However, rather than selecting records, I just want to see if the where statement evaluates to 'true', and if so, update a field in the row of the cursor.  Currently, for a selection I use:
where = "FullStreet = ('{}') AND inthousenum BETWEEN MinRange and MaxRange)".format(street)
 arcpy.SelectLayerByAttribute_management ("AddressPoints","ADD_TO_SELECTION",where)‍‍‍‍
So rather than select by attribute, I want to set a variable to 1 or 0 (or what ever) to indicate the success of the where statement, and take the appropriate action based on that value.
curtvpriceDan_Pattersondkwiens
That should just about do it....
JakeSkinner
Esri Esteemed Contributor
Hi Joe,
You could use the MakeFeatureLayer function and pass your where clause to that.  Then, execute the GetCount function to see if any records exist.
arcpy.MakeFeatureLayer_management("AddressPoints", "AddressPointsView", where)
count = int(arcpy.GetCount_management("AddressPointsView").getOutput(0))
if count > 0:
    # Perform action
else:
    # Where clause was invalid
DarrenWiens2
Can't you just use an UpdateCursor, rather than SearchCursor?
UpdateCursor—Help | ArcGIS for Desktop
JoeBorgione
After fiddling a bit with both approaches suggested, I'm still fumbling as usual.  None the less, perhaps a little more detail on my process may clarify things.
My intent is to cursor through a table and based on a couple field values, (I currently) select some records in a separate feature class.  The table is 3300 records and the feature class has 400,000+ records. Here is how I cursor through the table (called NoHitStreets):
fields = ["FullStreet","MinRange","MaxRange"]
with arcpy.da.SearchCursor("NoHitStreets", fields) as cursor:
    for row in cursor:
      streetlist = [row[0]]
      street = " ".join(streetlist)
      minlist = [row[1]]
      maxlist = [row[2]]
      intmin = int(minlist[0])
      intmax = int(maxlist[0])
      where = "FullStreet = ('{}') AND NumericHouseNum <=({}) AND NumericHouseNum >= ({})".format(street,intmax,intmin)
      arcpy.SelectLayerByAttribute_management ("AddressPoints","ADD_TO_SELECTION",where)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The NohitStreets table has a FullStreet field that is typically populated with something like "S MAIN ST" and it has two numeric fields MinRange and MaxRange which indicate the minimum and maximum bounding address ranges respectively, so values might 100 and 500.  I want to see if there are any points in the AddressPoints feature class that are on  S MAIN ST with a house number between 100 and 500.
This works, but with 3300 records to cursor through, and 400K+ points to select from, you can imagine it's pretty slow; and maybe that's just the nature of the beast.
The antithesis of this would be to cursor through the AddressPoints feature class, and see if there are any NoHitStreets records that meet that same basic criteria:
fields = ["FullStreet","NumericHouseNum"]
with arcpy.da.SearchCursor("AddressPoints", fields) as cursor:
         for row in cursor:
               housenumlist = [row[1]]
               inthousenum = int(housenumlist[0])
               where = "FullStreet = ('{}') AND {} BETWEEN MaxRange AND MinRange".format(street,inthousenum)
               arcpy.SelectLayerByAttribute_management ("NoHitStreets","ADD_TO_SELECTION",where)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
 I tried adding an UpdateCursor at the location of the SelectLayerByAttribute_management line in this second scenario and it failed miserably:
###........where = "FullStreet = ('{}') AND {} BETWEEN MaxRange AND MinRange".format(street,inthousenum,inthousenum)
update = ["UpdateField"]
with arcpy.da.UpdateCursor(myintable,update) as cursor:
            for row in cursor:
               row[0] =row[0] + 1
               cursor.updateRow(ro‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍w)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
### My concept, how ever flawed the execution may be,
### is to update the UpDateField value in the NoHitsTable from
### 0 (zero) to 1 (one)
### This tells me "hey, you have at least one address point
### on this street within this range.  which the begs the question:
### Why don't you have corresponding centerline geometry?"‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Either way, I'd like to some how flag a record in the NoHitsTable when a corresponding AddressPoint feature meets the "Where" criteria. If anything I hope I'm providing you guys with a few laughs as I fumble and bumble my through this.....
Darren Wiens‌  Jake Skinner
DarrenWiens2
Ah, okay. Here are my thoughts on speed, but someone correct me if I'm wrong.
So, I think you should load the points into a dictionary and read through streets with UpdateCursor. For each street, fetch the matching points and test whether they meet the street min/max criteria. If so, update the street row. Not sure if 400,000 records is reasonable for a dictionary, but I'd think so.
JoeBorgione
Thanks Darren-  checking in here a little late at night, but I'll take at look at what you suggest in the morning.  I actually let the selection scenario run as Ieft the office; just wanted to  have something to show the client.  I ran it a small set of points, and figured out a post process of the selected records of points and how they relate back to the no hits data.  Sometimes a little strong arm data processing is warrented.   I'll have soemthing to show, but I would very much like to improve my skills.
Thanks again-
dkwiens
