Error 001332
4329
6
05-15-2017 01:41 PM
KarenFolger
I'm getting this error in a script trying to loop through a SQL Enterprise GeoDB and Register As Versioned all the Feature Classes within it. It keeps telling me I'm trying to do this on a Feature Dataset but there aren't any feature datasets in the GeoDB. I'm doing a describe to check for feature class since there are some tables. What is this about? Tried in 10.4.1 and 10.5.
MichaelMiller2
You might want to include your script to aid with trouble shooting.
KarenFolger
import arceditor
# Import arcpy module
import os
import arcpy
from arcpy import env
inSDE = "\\\\server\\ArcSDE Connection Files\\GENgis_GISDB.sde"
env.workspace = inSDE
# Get List of Rasters in workspace
fcList = arcpy.ListFeatureClasses()
for fc in fcList:
   desc = arcpy.Describe(fc)
   if desc.dataType == "FeatureClass":
# Process: Register As Versioned
      arcpy.AddMessage("Trying: " + fc)
      outFC = os.path.join(inSDE, fc)
      arcpy.RegisterAsVersioned_management(outFC, "NO_EDITS_TO_BASE")
      arcpy.AddMessage(fc + " Registered as Versioned")
# Process: Change Privileges
      arcpy.ChangePrivileges_management(outFC, "public", "GRANT", "")
      arcpy.AddMessage(fc + " Granted Public permissions")
# Process: Add Global IDs
      arcpy.AddGlobalIDs_management(outFC)
      arcpy.AddMessage(fc + " now has Global IDs")
   else:
      arcpy.AddMessage("Skip table: " + fc)
Lake_Worth_BeachAdmin
import arceditor
import os
import arcpy
for fc in fcList:
   else:
ErikLima
I has this issue too.
Someone have an idea to solution?
Tks!
Here is a script I use
import arcpy
sde_path = r"C:\Users\GIS.sde"
arcpy.env.workspace = sde_path
datasets = arcpy.ListDatasets('*', 'ALL')
failedData = []
sucdata = []
for data in datasets:
    try:
        arcpy.RegisterAsVersioned_management(data, 'NO_EDITS_TO_BASE')
        sucdata.append(data)
        print str(data) + " completed"
        print "\n"
    except arcpy.ExecuteError:
        failedData.append(data)
        print str(data) +' failed'
        print arcpy.GetMessages(2)
        print "\n"
        continue
print 'list of data sets that successfully enabled versioning...'
for item in sucdata:
    print item
print "\n"
print 'List of Data Sets which failed to register as Versioned'
for item in failedData:
    print item
DanielMcBride
Did you ever figure out a way around the error? Specifically, arcpy telling you the feature classes couldn't be registered as versioned because they were part of a feature dataset [even though they weren't part of a feature dataset]? I'm running into this now in an Oracle GDB. Script below:
import os
import arcpy
import time
arcpy.env.workspace = "Database Connections\\_MVR NAVCHARTS.sde\\"
fcList = arcpy.ListFeatureClasses("NAVCHARTS*")
lockedList = []
for fc in fcList:
if arcpy.Describe(fc).isVersioned:
print fc + " already registered as versioned "+time.asctime()
else:
if arcpy.TestSchemaLock(fc):
print fc + " registering feature class as versioned "+time.asctime()
arcpy.RegisterAsVersioned_management(fc, "NO_EDITS_TO_BASE")
else:
print fc + " feature class locked, adding to locked list "+time.asctime()
lockedList.append(fc)
print "feature classed registered"+time.asctime()
print "following feature classed were locked and not registered: " + lockedList
This seems to handle the already-versioned and the locked feature classes as intended, but gives me the same error (001332) when it hits an unregistered and unlocked feature class.
