ERROR 000358: Invalid expression Failed to execute (SelectLayerByAttribute)
14898
24
12-04-2015 11:45 AM
mattstutts
My python script in ArcMap has an initial dialog box with two inputs: REG_CODE (values are in a list and include 'AKR', 'IMR', 'NER', etc) and Selection_type which offers 'NEW_SELECTION', 'REMOVE_FROM_SELECTION', etc.
My code runs just fine unless I pick the value 'NER'. Then I get this error:
Traceback (most recent call last): File "C:\Temp\SelectRegionalCREnterpriseData.py", line 99, in selectRelatedRecords(originTable, destinationTable, primaryKeyField, foreignKeyField) File "C:\Temp\SelectRegionalCREnterpriseData.py", line 96, in selectRelatedRecords arcpy.SelectLayerByAttribute_management(destinationTable, selectType, whereClause) File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 6688, in SelectLayerByAttribute raise e ExecuteError: ERROR 000358: Invalid expression Failed to execute (SelectLayerByAttribute).
I can verify that my layers and tables have a valid field called REG_CODE, that 'NER' does exist as an attribute value, and that there are no associated NULL values in the CR_ID field.
The script does two things... 1) goes through each layer, and selects features where REG_CODE = (say, NER) 2) Finds all records in CR_Catalog table where REG_CODE = and then selects the related records in the CR_Link table.
import arcpy, os, string
import arcpy.mapping as MAP
#Needed CR layers as well as Catalog and Link tables should be loaded into current mxd
mxd = MAP.MapDocument("CURRENT")
df = MAP.ListDataFrames(mxd)[0]
#set Reg_Code value for regional data into a sql expression
fld = arcpy.AddFieldDelimiters(arcpy.env.workspace, "REG_CODE")
sqlExp = fld + " = " + " '{0}' ".format(arcpy.GetParameterAsText(0))
arcpy.AddMessage(sqlExp)
#set selection type
selectType = arcpy.GetParameterAsText(1)
#Make lists of all feature layers and another list of all tables in dataframe
layers = MAP.ListLayers(mxd, "", df)
tables = MAP.ListTableViews(mxd, "", df)
#Set destinationTable (CR_Link) to empty string. This gets populated only if Link table is loaded into mxd.
# else, the select layer by attribute tool doesn't run
destinationTable = ""
originTable = ""
#used in generating list of related CR_IDs for match Catalog to Link table. Related by CR_ID field.
primaryKeyField = "CR_ID"
foreignKeyField = "CR_ID"
#These will be used to get records in Link that are related to Catalog where #Reg_Code = <input>
for table in tables:
  descTable = arcpy.Describe(table)
  tableNameList = (descTable.name).split(".")
  tableName = tableNameList[-1]
   if tableName == "CR_Catalog":
  originTable = table
   elif tableName == "CR_Link":
  destinationTable = table
   else:
   pass
#Main code to select all records in Catalog with matching Reg_code and then getting related records in Link table
if not str(destinationTable) == "" and not str(originTable) == "":
   def buildWhereClauseFromList(originTable, primaryKeyField, valueList):
   # Add DBMS-specific field delimiters
  fieldDelimited = arcpy.AddFieldDelimiters(arcpy.Describe(originTable).path, primaryKeyField)
   # Determine field type
  fieldType = arcpy.ListFields(originTable, primaryKeyField)[0].type
   # Add single-quotes for string field values
   if str(fieldType) == 'String':
  valueList = ["'%s'" % value for value in valueList]
   # Format WHERE clause in the form of an IN statement
  whereClause = "%s IN(%s)" % (fieldDelimited, ', '.join(map(str, valueList)))
   return whereClause
 def selectRelatedRecords(originTable, destinationTable, primaryKeyField, foreignKeyField):
   ## Defines the record selection from the record selection of the OriginTable
   ## and applys it to the DestinationTable using a SQL WHERE clause built
   ## in the previous defintion"""
   # Set the SearchCursor to look through the selection of the OriginTable
  sourceIDs = set([row[0] for row in arcpy.da.SearchCursor(originTable, primaryKeyField, sqlExp)])
# Establishes the where clause used to select records from DestinationTable
  whereClause = buildWhereClauseFromList(destinationTable, foreignKeyField, sourceIDs)
   # Process: Select Layer By Attribute
   # Process: Select related records between OriginTable and DestinationTable
   del tables, tableName, tableNameList, primaryKeyField, foreignKeyField
   del originTable, destinationTable
#If Link isn't in mxd, send a message
else:
  arcpy.AddMessage("CR_Link and CR_Catalog tables must be added to dataframe in order to create selection in CR_Link")
for lyr in layers:
  fieldList = arcpy.ListFields(lyr.dataSource, "REG_CODE")
   if len(fieldList) == 1:
  arcpy.SelectLayerByAttribute_management(lyr, selectType, sqlExp)
   else:
   pass
del lyr, layers,
del sqlExp, fld, mxd, df, fieldList
BruceHarold
Esri Frequent Contributor
This may be workspace specific then, when we get your data we'll load it into an enterprise database (what DBMS is yours?) and see what happens.
mattstutts
Thanks!! It's sql server 2012.
Matt Stutts, GIS Specialist
Cultural Resources GIS
National Park Service
Washington, DC
202-354-2149
www.nps.gov/crgis
www.facebook.com/crgis
mattstutts
Thank you.  I you a link yesterday through email to download some data.  I appreciate this greatly.  We are using SQL Server 2012.
mattstutts
Also, that part of the code with the IN(%)....  I'm not passing 'NER' there.  The guid string values from my CR_ID field are being passed in there.  I believe.
mattstutts
Tried it.  I'd have to first do a full selection on the first table (CR_Catalog) instead of using arcpy.da.SearchCursor.  I see how it can get me around a potential sql formatting problem but I'm not convinced that's what's going on here.  Still, it might be an option.
