ERROR 000358: Invalid expression Failed to execute (SelectLayerByAttribute)
14956
24
12-04-2015 11:45 AM
mattstutts
My python script in ArcMap has an initial dialog box with two inputs: REG_CODE (values are in a list and include 'AKR', 'IMR', 'NER', etc) and Selection_type which offers 'NEW_SELECTION', 'REMOVE_FROM_SELECTION', etc.
My code runs just fine unless I pick the value 'NER'. Then I get this error:
Traceback (most recent call last): File "C:\Temp\SelectRegionalCREnterpriseData.py", line 99, in selectRelatedRecords(originTable, destinationTable, primaryKeyField, foreignKeyField) File "C:\Temp\SelectRegionalCREnterpriseData.py", line 96, in selectRelatedRecords arcpy.SelectLayerByAttribute_management(destinationTable, selectType, whereClause) File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 6688, in SelectLayerByAttribute raise e ExecuteError: ERROR 000358: Invalid expression Failed to execute (SelectLayerByAttribute).
I can verify that my layers and tables have a valid field called REG_CODE, that 'NER' does exist as an attribute value, and that there are no associated NULL values in the CR_ID field.
The script does two things... 1) goes through each layer, and selects features where REG_CODE = (say, NER) 2) Finds all records in CR_Catalog table where REG_CODE = and then selects the related records in the CR_Link table.
import arcpy, os, string
import arcpy.mapping as MAP
#Needed CR layers as well as Catalog and Link tables should be loaded into current mxd
mxd = MAP.MapDocument("CURRENT")
df = MAP.ListDataFrames(mxd)[0]
#set Reg_Code value for regional data into a sql expression
fld = arcpy.AddFieldDelimiters(arcpy.env.workspace, "REG_CODE")
sqlExp = fld + " = " + " '{0}' ".format(arcpy.GetParameterAsText(0))
arcpy.AddMessage(sqlExp)
#set selection type
selectType = arcpy.GetParameterAsText(1)
#Make lists of all feature layers and another list of all tables in dataframe
layers = MAP.ListLayers(mxd, "", df)
tables = MAP.ListTableViews(mxd, "", df)
#Set destinationTable (CR_Link) to empty string. This gets populated only if Link table is loaded into mxd.
# else, the select layer by attribute tool doesn't run
destinationTable = ""
originTable = ""
#used in generating list of related CR_IDs for match Catalog to Link table. Related by CR_ID field.
primaryKeyField = "CR_ID"
foreignKeyField = "CR_ID"
#These will be used to get records in Link that are related to Catalog where #Reg_Code = <input>
for table in tables:
  descTable = arcpy.Describe(table)
  tableNameList = (descTable.name).split(".")
  tableName = tableNameList[-1]
   if tableName == "CR_Catalog":
  originTable = table
   elif tableName == "CR_Link":
  destinationTable = table
   else:
   pass
#Main code to select all records in Catalog with matching Reg_code and then getting related records in Link table
if not str(destinationTable) == "" and not str(originTable) == "":
   def buildWhereClauseFromList(originTable, primaryKeyField, valueList):
   # Add DBMS-specific field delimiters
  fieldDelimited = arcpy.AddFieldDelimiters(arcpy.Describe(originTable).path, primaryKeyField)
   # Determine field type
  fieldType = arcpy.ListFields(originTable, primaryKeyField)[0].type
   # Add single-quotes for string field values
   if str(fieldType) == 'String':
  valueList = ["'%s'" % value for value in valueList]
   # Format WHERE clause in the form of an IN statement
  whereClause = "%s IN(%s)" % (fieldDelimited, ', '.join(map(str, valueList)))
   return whereClause
 def selectRelatedRecords(originTable, destinationTable, primaryKeyField, foreignKeyField):
   ## Defines the record selection from the record selection of the OriginTable
   ## and applys it to the DestinationTable using a SQL WHERE clause built
   ## in the previous defintion"""
   # Set the SearchCursor to look through the selection of the OriginTable
  sourceIDs = set([row[0] for row in arcpy.da.SearchCursor(originTable, primaryKeyField, sqlExp)])
# Establishes the where clause used to select records from DestinationTable
  whereClause = buildWhereClauseFromList(destinationTable, foreignKeyField, sourceIDs)
   # Process: Select Layer By Attribute
   # Process: Select related records between OriginTable and DestinationTable
   del tables, tableName, tableNameList, primaryKeyField, foreignKeyField
   del originTable, destinationTable
#If Link isn't in mxd, send a message
else:
  arcpy.AddMessage("CR_Link and CR_Catalog tables must be added to dataframe in order to create selection in CR_Link")
for lyr in layers:
  fieldList = arcpy.ListFields(lyr.dataSource, "REG_CODE")
   if len(fieldList) == 1:
  arcpy.SelectLayerByAttribute_management(lyr, selectType, sqlExp)
   else:
   pass
del lyr, layers,
del sqlExp, fld, mxd, df, fieldList
DanPatterson_Retired
can you format your code using Python code blocks in the Syntax Highligher section,  >>> It is hard to follow the indentation
DarrenWiens2
What is the result of 'print whereClause'?
mattstutts
That gives me: CR_ID IN ('{guid]}', '{guid}', etc).
Basically, a list of string values that come from the field CR_ID from the CR_Catalog table.  I get these returned no matter the REG_CODE value I choose... even 'NER'.
did you copy that or type it since there is an unclosed ] after the first guid  ( IN ('{guid X }'
mattstutts
Sorry... typo.  CR_ID IN ('{guid}', '{guid}', etc)
BruceHarold
Esri Frequent Contributor
Hi
Please take a look at this as an alternate solution:
http://www.arcgis.com/home/item.html?id=e638afe0695a4ad38388cb8d9b350446
Regards
can't open on iThingy...got a snippet from there demonstrating the principles Bruce?
BruceHarold
Hi
The code makes Python sets from field values and does comparisons between sets.
No joins required, no SQL.  If you can even only download the zipfile the .py is there.
Thanks Bruce...zips and iThingy don't get along, I will check later.  But in short all set operations can be used then I presume which would be nice and hopefully cut out all that syntax error stuff.
