env() reference
52720
30
02-05-2020 10:13 AM
by Anonymous User
Not applicable
Hi, I'm trying to use Pycharm, as IDE for python, but it seemd that the function arcpy.env is missing from __init_.PY...
I'm using C:\Python27\ArcGISx6410.5 interpreter.
When I try to run it inside PyCharm I get :
C:\Python27\ArcGISx6410.5\python.exe U:/Prog/PYScript/Geosoft2ArcGIS.py
File "U:/Prog/PYScript/Geosoft2ArcGIS.py", line 12, in <module>
import arcpy
File "c:\arcgis\desktop10.7\ArcPy\arcpy\__init__.py", line 22, in <module>
from arcpy.geoprocessing import gp
ImportError: cannot import name gp
by Anonymous User
Not applicable
You have to point pycharm to use the pythonw.exe (or python.exe) that is in the same path as arcpy. "c:\arcgis\desktop10.7\ArcPy\....
I've pointed Pycharm to C:\Python27\ArcGIS10.7, but arcpy is somewhere else, in the ArcGIS folder, C:\ArcGIS\Desktop10.7\arcpy,
They are in seperate folders. no Python.exe in Arcpy folder (clean install)
DanPatterson_Retired
sorry, not an arcmap user... conda and Pro and Spyder
But
Importing ArcPy—Help | ArcGIS Desktop
gives a protracted discussion of sys paths and paths and imports.  In essence, you IDE has to make sure it can find arcpy especially if it was installed before arcmap.
Perhaps one of the lurking pycharm ers or pyscripter s will leap in to the rescue to sort out your dilema
Joshua Bixby‌ ? Joe Borgione‌ ? Matthew Driscoll‌ ? amongst the arcmap users viewing this thread.  Any ideas? (besides switching to ArcGIS Pro)
by Anonymous User
Not applicable
Thanks for your help.
JoshuaBixby
MVP Esteemed Contributor
Yves Allaire‌, let's cut out the script itself and try just running the import codes from within the Python console in PyCharm, just make sure the console interpreter is set to the same one you want to test.
PyDev console: starting.
Python 2.7.16 (v2.7.16:413a49145e, Mar  4 2019, 01:30:55) [MSC v.1500 32 bit (Intel)] on win32
by Anonymous User
Not applicable
Hi Joshua,
JoshuaBixby
Your screenshot shows you running the script.  I am asking you to open a clean Python console and try importing the arcpy module.
by Anonymous User
Not applicable
When I create a new project from scratch and go to the Python console here is what I get:
import arcpy
C:\Python27\ArcGIS10.7\python.exe "C:\Program Files\JetBrains\PyCharm Community Edition 2019.3.2\plugins\python-ce\helpers\pydev\pydevconsole.py" --mode=client --port=61237
import sys; print('Python %s on %s' % (sys.version, sys.platform))
sys.path.extend(['U:\\Prog\\PYScript\\untitled', 'U:/Prog/PYScript/untitled'])
import arcpy
File "<input>", line 1, in <module>
File "C:\Program Files\JetBrains\PyCharm Community Edition 2019.3.2\plugins\python-ce\helpers\pydev\_pydev_bundle\pydev_import_hook.py", line 21, in do_import
module = self._system_import(name, *args, **kwargs)
File "C:\ArcGIS\Desktop10.7\ArcPy\arcpy\__init__.py", line 22, in <module>
JoshuaBixby
Are you able to import any packages for that Python bundle, e.g., numpy, xlrd, etc...
by Anonymous User
Not applicable
I was able to import (install) them
Joe means import from the command line in the python IDE, not install them.  The packages may indeed be installed but in a different "Site Packages"
