Drawing Parallel Lines inside Polygons
8273
11
01-04-2019 02:20 PM
AdamThompson3
Hey Everyone,
I am basically trying to recreate the tool that was done here arcpy - Drawing parallel lines inside polygons (Well Paths) using ArcGIS Desktop? - Geographic Infor...
But It seems to not be working for me, I am running into errors within the copy features management portion of the script. It seems the dictionary I am trying to copy from is remaining empty even though the script appends to it.
I am a little unsure of what is completely going on in this script but was wondering if anyone else was able to get it to work and could shed some light and maybe how they did if possible?
Cheers
JamesGuilford
Does anyone know if this script still works in arcmap 10.6? I've tried running it but it just runs forever and does nothing.
RandyBurton
It should run with 10.6.  I assume you are running the script as a script tool inside ArcMap.  Can you describe your process, what parameters you are using, etc.?
