Doubts in arcpy.da.UpdateCursor
1238
11-09-2019 10:34 AM
SoratoSouza_e_Silva
My statement below create and update one new colunm with area calculated and after convert to other mensure splitting by 43560.
import arcpy
arcpy.env.workspace = "C://EsriTraining/PYTH/Cursors/Corvallis.gdb"
with arcpy.da.UpdateCursor("Parcel", ["SHAPE@AREA", "ACRES"]) as cursor:
      for row in cursor:
      geom = row[0]
      row[1] = geom / 43560
      cursor.updateRow(row)
Why have I to use geom equals row [0]?? There is no geom colunm in my feature...
Thank´s
XanderBakker
Esri Esteemed Contributor
Hi André Souza ,
The sample script indeed does not return the actual geometry, but a specific property of the geometry (in this case the area of the geometry using the SHAPE@AREA token). See UpdateCursor—Help | ArcGIS Desktop
The cursor is a collection of rows and each row is represented as a tuple. The way to access the values in each row is by using the index. row[0] refers to the first item in the tuple that corresponds to the order of your field list, in this case the area in sq ft (SHAPE@AREA). To convert this to acres you have to divide by 43560. The result is written to row[1] which refers to the ACRES field.
XanderBakker
Hi André Souza ,
SoratoSouza_e_Silva
Thank´s
