Does anyone know the alternate ArcPy function or tool for ArcSDE command: sdeversion -o close_state in ArcGIS 10.3 or 10.4
3612
7
07-11-2016 10:56 AM
by Anonymous User
Not applicable
We still need ArcSDE command ---sdeversion -o close_state to close the unclosed states in our versioning database sometime. Can anyone tell me what is the alternate ArcPy function or tool for that command in ArcGIS 10.3 or 10.4 or some functions I can put in Python script? Thanks
DanPatterson_Retired
None here Alphabetical list of ArcPy functions—Help | ArcGIS for Desktop
and if the functionality doesn't exist as a tool in arctoolbox, arcpy and python aren't going to help
ChristianWells
Xiaoyue Chen​ currently this does not exist within the GUI or arcpy module. Instead of looking at the need to close states, can you please elaborate on how open states are being created? When edited via the ArcGIS client, states should be closed following the transaction.
by Anonymous User
Not applicable
It caused by some hung processes with editing operation. It happened some days but not everyday.
>>> Christian Wells <geonet@esri.com> 7/11/2016 11:20 AM >>>
GeoNet
( https://community.esri.com/?et=notification.mention)
You have been mentioned by Christian Wells
( https://community.esri.com/people/Christian_Wells-esristaff?et=notification.mention) in Re: Does anyone know the alternate ArcPy function or tool for ArcSDE command: sdeversion -o close_state in ArcGIS 10.3 or 10.4 in GeoNet - View Christian Wells's reference to you
( https://community.esri.com/message/620177?et=notification.mention#comment-620177)
Xiaoyue Chen
( https://community.esri.com/people/xchen_Tucson) currently this does not exist within the GUI or arcpy module. Instead of looking at the need to close states, can you please elaborate on how open states are being created? When edited via the ArcGIS client, states should be closed following the transaction.
Participate in the conversation by replying to this email
This email was sent by GeoNet because you are a registered user.
You may unsubscribe
( https://community.esri.com/unsubscribe.jspa?email=xiaoyue.chen%40tucsonaz.gov&token=0f857a3187b206c189473edb94d6fbfbbd702c38e03cb0bc3571699f092d58cc) instantly from GeoNet, or adjust email frequency in your email preferences
( https://community.esri.com/user-preferences!input.jspa)
ChristianWells
Hi Xiaoyue, have you raised this ArcMap hanging to Esri Technical Support? If not, I would recommend creating a case for investigation into the hanging issue.
by Anonymous User
Not applicable
Thank you, Christian. We did create a case to ESRI support for the hanging processes three months ago, and the command is one of the solutions for that case. After that, we still see the unusual opening states sometime, I have manually to close them.
ChristianWells
I found the case you had previously. I will be reviewing it with some colleagues here and will reach back out to gather more information from you.
by Anonymous User
Not applicable
Thank you. I would like to make an automatic process to close unusual opening states via python if I have to and it is possible
