deleting fields from a shapefile doesn't work in my python script
2597
05-24-2011 01:39 PM
YimeiWang
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
# Set a default workspace
gp.workspace = "C:\\arcgisserver\\gisdata"
gp.toolbox = "management"
KeepList = ['FID', 'Shape', 'AREA', 'PERIMETER', 'PLACENAME', 'INCORP_FLA', 'COUNTY', 'STATE', 'SMARTLABEL', 'JURIS_NA_8', 'TAID']
fields = gp.ListFields("KY_TaxAreas.shp")
for field in fields:
        if field.Name not in KeepList:
                gp.deletefield("KY_TaxAreas.shp", "field.Name")
                print field.Name + " is deleted"
The whole processing seems right, and I got all print message for those fields which I want to delete. However, when I open the shapefile in ArcCatalog, those deleting fields are still there. Any idea?
DarrenWiens2
Does it work if you remove the quotes from around "field.name"? If it stays in quotes, python tries to delete a field literally called "field.Name", not the variable value.
YimeiWang
Thank you so much, dkwiens! you fix the problem.
