Delete all empty shapefiles in a Folder
9596
11
09-25-2014 02:06 AM
MittRamgobin
I want to delete all empty shapefiles in a folder. The following is not working:
 #Find empty shapefiles and delete them
arcpy.env.workspace = r"S:\SupportServices\LGAShapefiles"
shapefiles = arcpy.ListFeatureClasses()
for shapefile in shapefiles:
if arcpy.management.GetCount(shapefile)[0]=="0"
     arcpy.Delete_management(shapefile)
     print shapefile + "Deleted"
Tags (1)
RiyasDeen
Hi Mitt,
It's the period character in your shapefile name that's creating the issue.
Change line 43 in above code to replace . with _
basefileName = arcpy.Describe(Struc).baseName.replace('.','_') + LGA
RiyasDeen
Hi Mitt,
It should be
if int(arcpy.GetCount_management(shapefile).getOutput(0)) == 0:
have a look at example 2 ArcGIS Desktop
MittRamgobin
Hi Riyas,
Thank you for your input.
I am now getting the following error:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rows: Dataset GISTRAN.SubstationCOOROW, SHIRE OF.shp does not exist or is not supported
Failed to execute (GetCount).
What is going on?
RiyasDeen
Hi Mitt,
Sorry, Get Count accepts a layer input. We need to create a layer from the shapefile and pass it as input to the get count tool. Use below code, tested. Mind the line intents
arcpy.env.workspace = r"C:\tempdelete\Test_road"
  layerName = arcpy.Describe(shapefile).baseName
  arcpy.AddMessage(layerName)
  arcpy.MakeFeatureLayer_management (shapefile, layerName)
  arcpy.AddMessage(arcpy.GetCount_management(layerName).getOutput(0))
  if int(arcpy.GetCount_management(layerName).getOutput(0)) == 0:
MittRamgobin
Hi Riyas,
This time it gets stuck at the MakeFeatureLayer
ERROR 000732: Input Features: Dataset GISTRAN.SubstationCOOROW, SHIRE OF.shp does not exist or is not supported
Failed to execute (MakeFeatureLayer).
MittRamgobin
import arcpy
import sys
import os
# Script to create LGA Map with WP Infrastructure
# Define variables
arcpy.env.workspace = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]"
arcpy.env.overwriteOutput = True
#LGA = arcpy.GetParameterAsText(0) # Input Required Local Government Area
LGA ="COOROW, SHIRE OF"
#Define Layers to Intersect
#1. Transmission Layers
T330OH = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_330kV_OH_Carrier"
T330UG = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_330kV_UG_Cable"
T220OV = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_220kV_OH_Carrier"
T132OH = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_132kV_OH_Carrier"
T132UG = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_132kV_UG_Cable"
T66OV = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_66kV_OH_Carrier"
T66UG = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_66kV_UG_Cable"
T33OH = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_33kV_OH_Carrier"
T33UG = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_33kV_UG_Cable"
TransStruc = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Trans_Structure"
Substation = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\[email protected]\GISTRAN.Transmission\GISTRAN.Substation"
#Group Transmission Values:
Transmission = (T330OH, T330UG, T220OV, T132OH, T132UG, T66OV, T66UG, T33OH, T33UG, TransStruc, Substation)
#2. Distrubution Layers
POLES = os.path.join("ARCFM.Structure", "ARCFM.Pole")
HVOH = os.path.join("ARCFM.Distribution_HV", "ARCFM.Conductor_HV")
HVUG = os.path.join("ARCFM.Distribution_HV", "ARCFM.Cable_HV")
LVOH = os.path.join("ARCFM.Distribution_LV", "ARCFM.Conductor_LV")
LVUG = os.path.join("ARCFM.Distribution_LV", "ARCFM.Cable_LV")
#Group Distribution Values
Distribution = (POLES, HVOH, HVUG, LVOH, LVUG)
#Select Required LGA
arcpy.MakeFeatureLayer_management("GISEXT.Local_Government_Authority", "LGAlyr")
fieldName = "NAME"
Query = "\""+fieldName+"\"='"+LGA+"'"
arcpy.SelectLayerByAttribute_management ("LGAlyr", "NEW_SELECTION", Query)
###arcpy.SelectLayerByAttribute_management ("LGAlyr", "NEW_SELECTION", """ "NAME" = 'ALBANY, CITY OF' """) - working code
for Struc in Transmission:
    outputPath = r"S:\SupportServices\LGAShapefiles"
    basefileName = arcpy.Describe(Struc).baseName + LGA
    fileFormat= '.shp'
    finalDest = os.path.join(outputPath,basefileName+fileFormat)
    arcpy.Clip_analysis(Struc, "LGAlyr",finalDest)
#arcpy.Clip_analysis(Struc,"LGAlyr", finalDest)
print "Transmission Shapefile Created"
##for Struc in Distribution:
##    outputPath = r"S:\SupportServices\LGAShapefiles"
##    basefileName = arcpy.Describe(Struc).baseName + LGA
##    fileFormat= '.shp'
##    finalDest = os.path.join(outputPath,basefileName+fileFormat)
##    arcpy.Clip_analysis(Struc, "LGAlyr",finalDest)
RiyasDeen
Hi Mitt,
MittRamgobin
Hi Riyas,
Now there is this
ExecuteError: ERROR 000210: Cannot create output S:\SupportServices\LGAShapefiles\GISTRAN_Trans_330kV_OH_CarrierKONDININ, SHIRE OF.shp
ERROR 000354: The name contains invalid characters
Failed to execute (Clip).
RiyasDeen
, in your shapefile name is creating issue with clip. Interestingly if your shape file name is GISTRAN.Trans_330kV_OH_CarrierKONDININ, SHIRE OF.shp (with period) it's slipping through
. is creating issue with make feature layer
It's better to avoid special characters in your shape file name all together.
Change your LGA name to Shire of KONDININ without , separator.
MittRamgobin
Works like a treat now!
Thank you Riyas
