Hi. Have problem with Creating buffer only in specific direction. What's wrong?
5615
16
02-11-2021 05:40 AM
konstantBrr
import arcpy, math, gc
# Workspace, overwrite
arcpy.env.workspace = r"D:\testScript\My.gdb"
# INPUTS
objects_input = "objects.shp" # must be polygons
objects = "objects_lyr.shp"
arcpy.MakeFeatureLayer_management(objects_input, objects)
# OUTPUTS, most temporal
result = "result.shp"
result_erase = "in_memory" + "\\" + "result_erase"
polygon = "in_memory" + "\\" + "polygon"
polygon_dissolve = "in_memory" + "\\" + "polygon_dissolve"
arcpy.CreateFeatureclass_management(arcpy.env.workspace, result, "POLYGON")
# Parameters
distance = 3 # distance for move in direction
direction = 90 # direction in degrees (90 is from north to south)
index = 0
# Set UpdateCursor
cur_objects = arcpy.da.UpdateCursor(objects, ("FID"))
for row_objects in cur_objects:
try:
fid = row_objects[0]
sql = '"FID" = ' + str(index)
index += 1
# Initialize lists
lines_list = []
lines_created = []
# Select current feature
arcpy.SelectLayerByAttribute_management(objects, "NEW_SELECTION", sql)
vertexes = "in_memory" + "\\" + "vertexes"
# Convert object to vertexes
arcpy.FeatureVerticesToPoints_management(objects, vertexes, "ALL")
index_vertex = 0
# Set SearchCursor for vertexes
cur_vertexes = arcpy.da.SearchCursor(vertexes, ("SHAPE@XY"))
for row_vertexes in cur_vertexes:
vertex_coords_x = row_vertexes[0][0]
vertex_coords_y = row_vertexes[0][1]
# Define points coordinates
point_move_x = vertex_coords_x - (distance) * math.cos(math.radians(direction))
point_move_y = vertex_coords_y - (distance) * math.cos(math.radians(90 - direction))
# Make list of points
new_line = ([[vertex_coords_x, vertex_coords_y], [point_move_x, point_move_y]])
lines_list.append(new_line)
# From second cycle
if index_vertex > 0:
lines_vertexes = ([[vertex_coords_x, vertex_coords_y], start_line])
lines_ends = ([[point_move_x, point_move_y], end_line])
lines_list.append(lines_vertexes)
lines_list.append(lines_ends)
start_line = [vertex_coords_x, vertex_coords_y]
end_line = [point_move_x, point_move_y]
index_vertex = index_vertex + 1
# Cycle that makes polylines from points
for lines_step in lines_list:
lines_created.append(arcpy.Polyline(arcpy.Array([arcpy.Point(*sour) for sour in lines_step])))
arcpy.FeatureToPolygon_management(lines_created, polygon)
arcpy.AggregatePolygons_cartography(polygon, polygon_dissolve, 1)
# Final editing
arcpy.Erase_analysis(polygon_dissolve, objects, result_erase)
arcpy.Append_management(result_erase, result, "NO_TEST")
arcpy.Delete_management("in_memory")
arcpy.Delete_management(vertexes)
start_line = []
# Clear selection, memory and deleting temps
arcpy.SelectLayerByAttribute_management(objects, "CLEAR_SELECTION")
print ("Object number: " + str(index - 1) + " -- done.")
gc.collect()
# Catch errors
except Exception as e:
pass
print ("Error:")
print (e)
print ("\n")
index += 1
_______________________________________________________
File "D:/testScript/myDBpy.py", line 10, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 6520, in MakeFeatureLayer
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset objects.shp does not exist or is not supported
Failed to execute (MakeFeatureLayer).
DavidPike
MVP Notable Contributor
I've not read the entire script, also please consider formatting it to make it easier to read.
I can however see a workspace envionment set as an FGDB, then referencing a shapefile called "objects.shp".
You wont have a shapefile in that workspace, so give the full path to the shapefile.
konstantBrr
# INPUTS
objects_input = r"D:\testScript\objects.shp" # must be polygons
# Parameters
distance = 9 # distance for move in direction
index = 0
# Set UpdateCursor
try:
index += 1
# Initialize lists
lines_list = []
lines_created = []
index_vertex = 0
# From second cycle
# Final editing
start_line = []
gc.collect()
# Catch errors
pass
print ("Error:")
print (e)
print ("\n")
index += 1
BlakeTerhune
Please mention any error messages or results that the script is currently producing.
konstantBrr
File "D:/testScript/myDBpy2.py", line 18, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 1807, in CreateFeatureclass
raise e
ExecuteError: ERROR 000354: The name contains invalid characters
Failed to execute (CreateFeatureclass).
by Anonymous User
Not applicable
You also have an updateCursor that probably can be a search cursor since it doesn't look like it is ever updating the row.
Another tip that I see is that your objects is pointing to 'objects_lyr.shp'.  Since it is only a view (think of it as a temporary copy of the original data that you can do stuff to), you don't need the .shp at the end.  It can live and be referenced as 'objects_lyr' and you can also reference it through assigning the MakeFeatureLayer to a variable.   This doesn't effect the code at all, but more of a FYI.
# INPUTS
 to
# INPUTS
objects_input = "objects.shp" # must fix this per David's response
objectOutName = "objects_lyr.shp"
objLyr = arcpy.MakeFeatureLayer_management(objects_input, "objects_lyr")
then replace 'objects' with 'objLyr' where needed so its more readable and people know that it is referring to a Layer.
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - GeoNet, The Esri Community would help with readability
... sort of retired...
konstantBrr
Thank You. I will try it!
konstantBrr
Still not workinng! May be cause  I'm verry junior in python coding for arcgis😔
# INPUTS
# Parameters
index = 0
# Set UpdateCursor
try:
index += 1
# Initialize lists
lines_list = []
lines_created = []
index_vertex = 0
# From second cycle
# Final editing
start_line = []
gc.collect()
# Catch errors
pass
print ("Error:")
print (e)
print ("\n")
index += 1
konstantBrr
raise e
