Customizing script tool to have split user inputs
2013
09-13-2021 09:16 AM
RPGIS
by MVP Regular Contributor
I was wondering if what I would like to customize for a custom script tool is even possible. The user input requires the user input for both the northing and easting coordinates. I was wondering if there is a way to set it up so that the inputs are side by side.
I don't know if this is possible or not but I just wanted to double check.
Luke_Pinner
Use a Value Table parameter:
JamesWilcox1970
You can use tkinter to create an input popup form. You can customize field position etc. I don't have any code sample to help you with, unfortunately.
RPGIS
I thought I discovered some documentation that showed how to. I will post it here if I ever stumble across it again.
Luke_Pinner
