Cursor if/then statements
1551
01-15-2020 01:33 PM
QuangTruong
Hi, I am trying to search through a dataset to find a certain value in a certain field in order to update another field in that same row, but I can't quite seem to make the code snippet work. Can somebody tell me what I'm doing wrong? The below code completes just fine but returns nothing.
import arcpy
arcpy.env.workspace = r"C:\Users\paperspace\Google Drive\QTA\19010_PDX Zoning\PDXZoning\PDX_Kerns.gdb"
fieldNames = ['TLID', 'RNO']
tlidList = arcpy.da.SearchCursor("taxlots_Kerns", fieldNames)
for tlids in tlidList:
    string = "*-STR*"
    if tlids[1] == string:
        print(tlids)
I can't tell if I'm using the wildcard incorrectly, the comparison incorrectly, or if there's something else I'm doing wrong. Thanks,
BlakeTerhune
Applying this logic to your code would be something like this.
import arcpy
find_string = "-STR"
with arcpy.da.SearchCursor("taxlots_Kerns", fieldNames) as tlidList:
    for tlid, rno in tlidList:
        if find_string in tlid:
            print(tlid)
DanPatterson_Retired
Strings are iterables, so you can look for substrings in strings
s = "-STR"
tlids = [ "abc", "-str", "A_STR", "a_-STR"]
[s in i for i in tlids]
[False, False, False, True]
BlakeTerhune
import arcpy
            print(tlid)
JoshuaBixby
MVP Esteemed Contributor
If you want to update rows, you should use an update cursor instead of a search cursor.  Instead of doing the string search in Python, you can also put a SQL WHERE clause when you set up the cursor:
import arcpy
sql = "RNO LIKE '%-STR%'"
with arcpy.da.UpdateCursor("taxlots_Kerns", fieldNames, sql) as cur:
    for row in cur:
        row.updateRow()  # update row with new values
