Creating Polylines with Z-values very slow
1299
07-17-2013 11:44 PM
AndreasKrueger
i am creating Polylines from scrath out of X,Y,Z-Points.
I need PolylineZ. When I create Polylines using arcpy.Polyline i use the Parameter "has_z = True".
If i use this Parameter, i get PolylineZ but it works that slow that the script is un-useable for me.
Without this paramater the script works fine and fast but without having Z-values.
How can i make the script faster? Has someone an idea?
Thanks.
Andy
lineArray = arcpy.Array()
pnt = arcpy.Point()
for f in list:
pnt.X = ...
pnt.Y = ...
pnt.Z = ...
lineArray.add(pnt)
feature = arcpy.Polyline(lineArray, "None", True, False)
featureList.append(feature)
lineArray.removeAll()
cursor = arcpy.da.InsertCursor(shpname, ["SHAPE@"])
for f in featureList:
cursor.insertRow()
JamesCrandall
Not sure if this would help, but perhaps this is causing the issue?
   cursor.insertRow()
Perhaps try:
with arcpy.da.InsertCursor(shpname, ["SHAPE@"]) as cursor:
    cursor.insertRow([featureList])
AndreasKrueger
Hi jamesfreddyc,
thanks for your reply,
the insertCursor-function is not the time killer.
the function arcpy.Polyline() is fast fithout the Parameter "has_z"
for example:
Synatx = Polyline (inputs, {spatial_reference}, {has_z}, {has_m})
polyline = arcpy.Polyline(array)    #this one is fast as expected
polyline = arcpy.Polyline(array, <none>,  True, False)    #this one is very very very slow
JamesCrandall
Hi jamesfreddyc,
for example:
Okay, perhaps this is the issue:
http://resources.arcgis.com/en/help/main/10.1/index.html#//018w0000000t000000
"...When using InsertCursor on a point feature class, creating a PointGeometry and setting it to the SHAPE@ token is a comparatively expensive operation. Instead, define the point feature using tokens such as SHAPE@XY, SHAPE@Z, and SHAPE@M for faster, more efficient access."
I will look for an example of setting SHAPE@Z
KoenVolleberg
Hi all,
I come up with the same issue.
Anyone found a solution yet?
The last suggestion  jamesfreddyc did works for point features, not for polyline features.
Cheers, Koen
