locked by another application _ Error
785
12-05-2013 08:10 PM
H_A_D_Padmasiri
When i run script, it works without any error. But when i try to run again the following message appear.
ExecuteError: ERROR 000601: Cannot delete J:\Gampaha\51027202\CM51027202.gdb.  May be locked by another application.
is it my problem?. pl explane how to remove that lock
Padmasiri
JakeSkinner
Esri Esteemed Contributor
Hi Padmasiri,
Can you post the code of your script?
