Create Users with Python API - Using up licenses during creation of users.
3096
6
03-26-2024 01:56 PM
SGTomlins
I am using the source code from the API page for cloning.
Clone Portal users, groups and content | ArcGIS API for Python
My particular problem is that the user creation by default sets my "type" to "Creator".  The "New Member Defaults" setting on the target portal is type:"Viewer" and role:"Viewer".
The API documentation I am following:arcgis.gis module | ArcGIS API for Python
The area I am working with:
create(usernamepasswordfirstnamelastnameemailroledescription=Noneprovider='arcgis'idp_username=Nonelevel=2thumbnail=Noneuser_type=Nonecredits=- 1groups=Noneemail_text=None)
Code being executed:
target_user = target_portal.users.create(source_user.username, password, first_name, last_name,
source_user.email, source_user.description , source_user.role)
All this runs and creates the users ("Members") in the portal.  but uses the "Creator" and NOT the "Viewer" type.  The source information evidences that the user is "arcgisonly" among everything else.  This is a listing from the dictionary values from the output of:
source_users = source.users.search('!esri_ & !admin',max_users=260)
for user in source_users:
print(user.username + "\t:\t" + str(user.role))
for key, value in user.__dict__.items():
print(f"{key}: {value}")
[email protected] : org_user
_gis: GIS @ https://maps.ci.janesville.wi.us/portal version:8.2
_portal: <arcgis.gis._impl._portalpy.Portal object at 0x0000020091F49588>
_user_id: [email protected]
thumbnail: None
_workdir: C:\Users\tomlinss\AppData\Local\Temp
_hydrated: True
username: [email protected]
fullName: Trderman
firstName: Tra
lastName: rman
preferredView: None
description: None
email: [email protected]
userType: arcgisonly
idpUsername: [email protected]
favGroupId: 47210944c0fc4783b1dfc0bbdb0a882a
lastLogin: -1
mfaEnabled: False
validateUserProfile: True
access: public
storageUsage: 22101499
storageQuota: 10995116277760
orgId: 0123456789ABCDEF
role: org_user
privileges: ['portal:user:joinGroup', 'portal:user:viewOrgGroups', 'portal:user:viewOrgItems', 'portal:user:viewOrgUsers', 'premium:user:demographics', 'premium:user:elevation', 'premium:user:geocode', 'premium:user:networkanalysis']
adminCategories: []
roleId: iAAAAAAAAAAAAAAA
level: 1
userLicenseTypeId: viewerUT
disabled: False
tags: []
culture: en-US
cultureFormat: us
region: None
units: english
created: 1683063913118
modified: 1683063943058
provider: enterprise
groups: [{'id': 'c5aa36caa6534a8dbf3cd6bdfff83870', 'title': 'City Employees Maps and Apps', 'isInvitationOnly': True, 'owner': 'GIS_Admin', 'description': None, 'snippet': 'City Employees Maps and Apps. Our current Geocortex Essentials City Employees website requires an individual portal user for each staff member in order to access the site.\n', 'tags': ['City Employees', 'Geocortex Essentials'], 'phone': None, 'sortField': 'title', 'sortOrder': 'asc', 'isViewOnly': False, 'thumbnail': None, 'created': 1683063248170, 'modified': 1683226178816, 'access': 'org', 'capabilities': [], 'isFav': False, 'isReadOnly': False, 'protected': True, 'autoJoin': False, 'notificationsEnabled': False, 'provider': None, 'providerGroupName': None, 'leavingDisallowed': True, 'hiddenMembers': True, 'membershipAccess': 'org', 'displaySettings': {'itemTypes': ''}, 'userMembership': {'username': '[email protected]', 'memberType': 'member'}}]
These are the setting of my source and destination portals.
source   {'role': 'iAAAAAAAAAAAAAAA', 'userLicenseType': 'viewerUT', 'groups': ['e63f5cd74ea04cd691a05e4c84922236'], 'userType': None, 'apps': [], 'appBundles': []}
target    {'role': 'iAAAAAAAAAAAAAAA', 'userLicenseType': 'viewerUT', 'groups': ['19c30fa791c24145ad417115fcb2bbab'], 'userType': None, 'apps': [], 'appBundles': []}
Can someone please point me to why the creation of new users is ignoring the defaults, and possible why the cloning operation is ignoring the source user type and role..
Thank you...
2 Solutions
SGTomlins
I got this to work, but it forces all created users to be type: "Viewer" and role: "Viewer".
This is a workaround solution... not an actual cloning..
password,
first_name,
last_name,
source_user.email,
source_user.description,
role = "iAAAAAAAAAAAAAAA",
user_type = "Viewer"
Still wondering on how to get source users values to actually "clone" the environment.
I will look at the dictionary values and see if I can grab the right ones? ? ? ? ? ?
SGTomlins
BUG-000167590: Clone users does not honor source role user type or role
We apologize for the inconvenience and thank you for bringing this to our attention. This issue will now be reviewed by our development team and for status information and updates on this,
HenryLindemann
Hi @SGTomlins in your script you have level=2 this is a creator type.
Kind Regards
Henry
SGTomlins
Hi Henry,
The level=2 in the code snippet is from the ESRI API example.  I tried level=1 during the many run-break-fix cycles.  It failed too.  I tried this:
password,
first_name,
last_name,
source_user.email,
source_user.role,
user_type= "Viewer"
But I get the following:
The user's role does not allow the specified user type to be set.
(Error Code: 500)
Unable to create user [email protected]
My user role returns "org_user".   I can't find a lower role with the presumption that "org_user" is a step above "org_viewer".  hence not being able to have a role of Viewer with a user that can edit.
Why does the user creation ignore the defaults when I specify neither role or type?
How can I avoid the conflict of user/role in the target using the "users.create" ?
The source portal users are type: viewer and role: viewer.  The values returned to apply to the target portal users do not appear to match....  ???
-Steve
SGTomlins
password,
first_name,
last_name,
source_user.email,
JakeSkinner
Esri Esteemed Contributor
@SGTomlins you can take a look at the scripts here.  They have examples of creating users accounts.
SGTomlins
Thanks Jake..  I will take a look at those....   🙂
SGTomlins
