Create multiple points with mouse click
6486
13
07-24-2015 09:55 AM
PacoAlverez
I would like to be able to click multiple locations and create points where i click and populate each points x, y. i have the current code but only creates one point, so i needs help.
current code.
#import modules
import arcpy
arcpy.env.qualifiedFieldNames = False
An = "AnimalSightings" #target point feature class Animal Sightings
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(An).spatialReference
if dfsr.name == fcsr.name:
    """Now do your work"""
point = arcpy.GetParameterAsText(0)  #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
    x,y = prow[0]
del prow
row_value = [x,y,(x,y)]
with arcpy.da.InsertCursor(An,('POINT_X', 'POINT_Y','SHAPE@XY')) as cursor:
    cursor.insertRow(row_value)
DarrenWiens2
I'm not sure if you've got this figured out by now, but here is generally how you can add multiple points from a feature set to a feature class:
import arcpy
point = arcpy.GetParameterAsText(0) # the feature set (or in-memory fc)
pointFC = r'C:/junk/points.shp' # the on-disk fc
insCursor = arcpy.da.InsertCursor(pointFC,'SHAPE@XY') # create insert cursor
with arcpy.da.SearchCursor(point,'SHAPE@XY') as cursor: # loop through feature set
    for row in cursor:
        insCursor.insertRow(row) # insert row
del insCursor # delete insert cursor
Of course, you could just as easily run the Append tool rather than using cursors, but I assume you have a specific reason for going into this detail.
WesMiller
You first need to nest every thing under your if statement you'll be able to tell by the indentation
Then move line 19 below line 24 and nest everything 19 - 24 under the for statement. del prow should be aligned with the for statement be careful and watch your indentation it's important in python
PacoAlverez
Like so?
#import modules
import arcpy
pointCount = int(arcpy.GetCount_management(point).getOutput(0))
if  pointCount >= 1:
        x,y = prow[0]
del prow
WesMiller
Try to use the code below as a guide.
if sr == sr:
    for prow in SC:
        x,y
        row_value =
        with arcpy.da.insertCursor:
            cursor.insertRow()
    delprow
PacoAlverez
sorry, i was out for the weekend.
I was not able to get the code to allow me to create multiple points.
i a not sure what if sr ==sr: is doing other then comparing two values.
WesMiller
Were you able to get your code formatted correctly?
CCWeedcontrol
DarrenWiens2
import arcpy
    for row in cursor:
PacoAlverez
interesting. so if i wanted to populate the POINT_X and POINT_Y how would i do that.
I am having no luck, i am getting error:
  File "C:\GIS\Python\AddPoint\AddPoint_4.py", line 23, in <module>
    row[0] = centroid.x
NameError: name 'centroid' is not defined
#import modules
import arcpy
pointFC = "AnimalSightings" #target point feature class Animal Sightings
fcsr = arcpy.Describe(pointFC).spatialReference
        x,y = prow[0]
del prow
insCursor = arcpy.da.InsertCursor(pointFC,('POINT_X','POINT_Y','SHAPE@XY')) # create insert cursor
with arcpy.da.SearchCursor(point,('POINT_X','POINT_Y','SHAPE@XY')) as cursor: # loop through feature set
    for row in cursor:
        row[0] = centroid.x
        row[1] = centroid.y
DarrenWiens2
^ means there is no variable yet defined as "centroid". This "centroid" thing you are looking for is a property of a PointGeometry. A PointGeometry's centroid is a Point, which has properties 'X' and 'Y'.
Using SHAPE@XY:
This returns an x,y tuple, not a geometry object. You can create a Point from this tuple like so:
point = arcpy.Point(row[2][0],row[2][1])
print point.X
print point.Y
Using SHAPE@:
This returns the geometry itself, so if you are reading points, row[2] will be a point object.
