Create composite locator 100% unmatched
1485
10-21-2024 03:23 PM
LondonWalker
I am trying to create a composite locator in python, but it doesn't seem to work. All the points are left unmatched. The locators behind it work fine and I don't receive any errors. Is there something wrong in my code?
milepoints_prod = PROD_FOLDER+"\\"+milepoints_locator
census_prod = PROD_FOLDER+"\\" + census_locator
pa_prod = PROD_FOLDER+"\\" + pa_singlehouse
sa_prod = PROD_FOLDER+"\\" + sa_singlehouse
er_prod = PROD_FOLDER+"\\" + er_singlehouse
if os.path.exists(PROD_FOLDER+"\\"+pa_composite):
    os.remove(PROD_FOLDER+"\\"+pa_composite)
address = "Address 'Address or Place' true true false 100 Text 0 0,First,#,pa_prod,Address,0,0,milepoints_prod,Address,0,0,census_prod,Address,0,0;"
address_2 = "Address2 'Address2' true true false 100 Text 0 0,First,#,pa_prod,Address2,0,0,milepoints_prod,Address2,0,0,census_prod,Address2,0,0;"
address_3 = "Address3 'Address3' true true false 100 Text 0 0,First,#,pa_prod,Address3,0,0,milepoints_prod,Address3,0,0,census_prod,Address3,0,0;"
neighborhood = "Neighborhood 'Neighborhood' true true false 50 Text 0 0,First,#,pa_prod,Neighborhood,0,0,milepoints_prod,Neighborhood,0,0,census_prod,Neighborhood,0,0;"
city = "City 'City' true true false 50 Text 0 0,First,#,pa_prod,City,0,0,milepoints_prod,City,0,0,census_prod,City,0,0;"
county = "Subregion 'County' true true false 50 Text 0 0,First,#,pa_prod,Subregion,0,0,milepoints_prod,Subregion,0,0,census_prod,Subregion,0,0;"
STATE = "Region 'State' true true false 50 Text 0 0,First,#,pa_prod,Region,0,0,milepoints_prod,Region,0,0,census_prod,Region,0,0;"
ZIPC = "Postal 'ZIP' true true false 20 Text 0 0,First,#,pa_prod,Postal,0,0,milepoints_prod,Postal,0,0,census_prod,Postal,0,0;"
ZIP4 = "PostalExt 'ZIP4' true true false 20 Text 0 0,First,#,pa_prod,PostalExt,0,0,milepoints_prod,PostalExt,0,0,census_prod,PostalExt,0,0;"
country = "CountryCode 'Country' true true false 100 Text 0 0,First,#,pa_prod,CountryCode,0,0,milepoints_prod,CountryCode,0,0,census_prod,CountryCode,0,0"
composite_locator_field_map = address + address_2 + address_3 + neighborhood + city + county + STATE + ZIPC + ZIP4 + country
arcpy.geocoding.CreateCompositeAddressLocator(pa_prod+" PA_Singlehouse;"+milepoints_prod+" CDOT_Mile_Poin;"+census_prod+" Census_Roads", composite_locator_field_map, "PA_Singlehouse #;CDOT_Mile_Poin #;Census_Roads #", PROD_FOLDER+"\\"+pa_composite)
MichaelVolz
Esteemed Contributor
One thing to check is if Match without Zone is set to True as it is False by default.
MichaelVolz
