CopyRaster with Error 000732
1300
07-11-2013 05:15 AM
AlasdairMartin
I am writing some code that will automate the construction of 30 year monthly average gridded climate data in the United States. Recently, I've finished a draft but am tied up in an error that I cannot unravel. The code is in the grey box below. The error I am receiving (Error 000732) is below that. I ran the erroneous line in question on its own in the Python Script in ArcGIS 10.1 and it worked which has led me to even more confusion.
CODE:
 # IMPORT SYSTEM MODULES import arcpy from arcpy import env from arcpy.sa import *  # CHECK OUT ANY NECESSARY LICENSES arcpy.CheckOutExtension("spatial")  MonthDay = ["1/16/", "2/16/", "3/15/", "4/15/", "5/15/", "6/15/", "7/15/", "8/15/", "9/15/", "10/15/", "11/15/", "12/15/"]  # LOOP THROUGH MONTH AND DAYS for month in MonthDay:     LIST = []     NoBackslashMonth = month.replace("/", "")      # LOOP THROUGH THE YEAR 1970 AND 1999     for year in range(1970, 2000):         arcpy.MakeNetCDFRasterLayer_md(r"E:\Documents\Data\Climate\United States\1970-1999 (OBSERVED)\1970-1999CodePlayground.gdb\Extraction_Tavg.nc", "Tavg", "longitude", "latitude", NoBackslashMonth + str(year), "", [["time", month+str(year)]],"BY_VALUE")         LIST.append(NoBackslashMonth + str(year)) # ADDS RASTER DATA FOR THE YEAR "year" TO "LIST"      DATE = " " # CREATES/RESETS "DATE" VARIABLE      # IF STATEMENT THAT WILL PUT ABBREVIATED MONTH VALUES IN FOR THEIR CORRESPONDING NUMERIC ORDER     if month == '1/16/':         DATE = "jan"     elif month == '2/16/':         DATE = "feb"     elif month == '3/15/':         DATE = "march"     elif month == '4/15/':         DATE = "april"     elif month == '5/15/':         DATE = "may"     elif month == '6/15/':         DATE = "june"     elif month == '7/15/':         DATE = "july"     elif month == '8/15/':         DATE = "aug"     elif month == '9/15/':         DATE = "sep"     elif month == '10/15/':         DATE = "oct"     elif month == '11/15/':         DATE = "nov"     elif month == '12/15/':         DATE = "dec"     else:         print "no date"       output = arcpy.sa.CellStatistics(LIST, "MEAN", "NODATA") # CALCULATES THE 30 YEAR AVERAGE FOR "DATE"     arcpy.CopyRaster_management("output", "E:\\Documents\\Data\\Climate\\United States\\1970-1999 (OBSERVED)\\MonthlyTemperatureData.gdb\\" + DATE, "", "", "", "", "", "", "", "") # COPY'S "output" RASTER DATA SET as "DATE" in "MonthlyTemperatureData" GEODATABASE      # Clears the Table of Contents ######################     mxd = arcpy.mapping.MapDocument("CURRENT")     for df in arcpy.mapping.ListDataFrames(mxd):         for lyr in arcpy.mapping.ListLayers(mxd, "", df):             arcpy.mapping.RemoveLayer(df, lyr)     # Clears the Table of Contents ######################
ERROR:
 Traceback (most recent call last):    File "E:/Documents/Code/TestCode", line 53, in <module>       arcpy.CopyRaster_management("output", "E:\\Documents\\Data\\Climate\\United States\\1970-1999 (OBSERVED)\\MonthlyTemperatureData.gdb\\" + DATE, "", "", "", "", "", "", "", "") # COPY'S "output" RASTER DATA SET as "DATE" in "MonthlyTemperatureData" GEODATABASE    File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 11034, in CopyRaster raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Raster: Dataset output does not exist or is not supported Failed to execute (CopyRaster).
Thank you very much.
DuncanHornby
MVP Notable Contributor
Try dropping the "" around the word output in the CopyRaster tool.
DuncanHornby
AlasdairMartin
Thank you very much, that worked marvelously. I thought it would be something stupidly simple.
