add join failure and attribute table column limit
1156
07-10-2013 10:28 PM
ElaineKuo
System: ArcGIS 9.3 and Vista
Hello
I am using the function add join to combine three shape files into one shape file. (by python script)
Each of them has about 650 columns in the attribute table.
However, the add join always failed.
The error message is
Could not load data from the data source
If you can correct the problem, click the refresh button to refresh data.
Possible problems can include bad network connection, invalid field, etc.
An invalid SDE statement was used.
(I am sure nothing to do with invalid field,*
because all the shape files were produced by the add join method. )
I am wondering if the cause was the over-limit column number.
If so, please kindly advise alternative methods to complete the combination.
Thank you.
Elaine
DuncanHornby
MVP Notable Contributor
The answer to your question is here. I would also question the wisdom of any dataset with 650 columns...
