Converting folder of shape files to geodatabase
4797
08-31-2011 04:07 PM
RickWarner
I have a folder of 20 shape files and would like to covert folder to geodatabase, the code below will work and list the feature classes, but won't convert to geodatabase.  What am I doing wrong?
import arcpy
>>> from arcpy import env
>>> env.workspace = "D:/GIS/Data/Aug_Files"
>>> fcs = arcpy.ListFeatureClasses("*")
>>> arcpy.FeatureClassToGeodatabase_conversion("D:/GIS/Data/Aug_Files", "D:/GIS/PBCO2011/Planning.gdb")
The error message I get is "Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000732: Input Features: Dataset D:/GIS/Data/Aug_Files does not exist or is not supported .
Any ideas??
ModyBuchbinder
Hi Rick
The FeatureClassToGeodatabase_conversion get a comma delimited list of feature classes.
You should build this list from the ListFeatureClasses
Try something like this:
   s = "[ "
    for fc in fcList:
        print fc
        s = s + '"' + fc + '"' + " ,"
    # delete last comma and close brackets
    s = s[0:len(s) - 1] + " ]"
have fun
Mody
StephanieWendel
I think it's the "D:/GIS/Data/Aug_Files" in this line of code that is causing the problem.
Mody is right that you need to put your list of elements in this spot. Another way you can do it is like this:
import arcpy
for fc in fcs:
    arcpy.FeatureClassToGeodatabase_conversion(fc, "D:/GIS/PBCO2011/Planning.gdb")
The listFeatureClasses method link in the Help also has a sample of moving shapefiles into a geodatabase using the copyFeatures_management tool. See this link for more information on it: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/ListFeatureClasses/000v0000001n000000/
RickWarner
Thanks Stephanie and Mody, I got Stephanies to work right of way, still trying yours Mody. Again thanks so much.
