Converting date to string and combining fields using Python
2229
07-06-2018 01:10 PM
by Anonymous User
Not applicable
I'm trying to get more familiar with ArcGIS Pro and by necessity, Python. I have multiple feature classes that are assigned a unique identifier that combines the location and date/time that the data were collected in the format "PARK_YYYYMMDD_HHMMSS". "PARK" comes from a data field [Park_Unit] with a coded domain and date/time from a date field [TRT_BEG_TM]. I'm trying to get it to work using Python but I can't wrap my head around functions and syntax. Here's the VB Script expression I've been using in ArcMap for reference. Thanks in advance.
Pre-Logic Script Code:
strYear= Year( [TRT_BEG_TM] )
strMonth= Month ( [TRT_BEG_TM] )
strDay = Day( [TRT_BEG_TM] )
strHour = Hour( [TRT_BEG_TM] )
strMin = Minute( [TRT_BEG_TM] )
strSec = Second( [TRT_BEG_TM] )
If strDay < 10 Then
  strDay = "0"& strDay
end if
  If strMonth < 10 Then
strMonth = "0" & strMonth
end if
If strHour < 10 Then
  strHour = "0" & strHour
end if
If strMin < 10 Then
  strMin = "0" & strMin
end if
If strSec < 10 Then
  strSec = "0" & strSec
end if
Formatteddate= strYear & strMonth & strDay & strHour & strMin & strSec
LOC_NM=
[PARK_UNIT] &"_"& left(Formatteddate,8) & "_" & right(Formatteddate,6)
JoshuaBixby
MVP Esteemed Contributor
Forgot you were using ArcGIS Pro, the code above was built on ArcMap.  I will take a look at what has changed with Pro and see if I can tweak the code.
UPDATE:  Good news, Esri actually fixed the field calculator so it returns actual datetime objects instead of string representations of them.  The code is simpler with Pro:
"{}_{:%Y%m%d_%H%M%S}".format( !PARK_UNIT! ,!TRT_BEG_TM!)
JoshuaBixby
Try this in the expression box of field calculator:
"{}_{:%Y%m%d_%H%M%S}".format( !PARK_UNIT! ,arcpy.time.ParseDateTimeString( !TRT_BEG_TM!))‍‍
Unfortunately, and for reasons I don't understand, the field calculator returns datetimes as strings, which requires converting them back to datetime using arcpy.time if you want to use native Python datetime handling.
by Anonymous User
Not applicable
Hi Joshua, that expression returns the following error:
ERROR 000539: Traceback (most recent call last):
File "<expression>", line 1, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\time.py", line 300, in ParseDateTimeString
raise ValueError(datetime_string)
ValueError: 2018-06-28 15:27:48
JoshuaBixby
by Anonymous User
Not applicable
Fantastic, that worked, thanks very much.
