Convert Python Script to Tool with Parameters
2748
04-26-2021 10:06 AM
AndrewClark2
HI,
I have a script that runs perfectly fine using variables for the inputs. As soon as I turn them to parameters, I am running into a "RUN TIME ERROR" with no details. I cannot for the life of me figure out the issue. Any suggestions? The
Thanks!
Andrew
import arcpy as ap
import numpy as np
import os
# set environmental variables
ws=ap.GetParameterAsText(0)
gdb = ap.GetParameterAsText(1)
scratch = ap.GetParameterAsText(2)
# Set default geodatabase as workspace
ap.env.workspace = gdb
# Allow files to be overwritten by python code
ap.env.overwriteOutput = True
# Analysis Files
pc = ap.GetParameterAsText(5)
nds = ap.GetParameterAsText(3)
nd_layer_name = "NetworkDataSet"
Output_FD = ap.GetParameterAsText(7)
Imp = ap.GetParameterAsText(6)
Impedance = []
for x in Imp.split(';'):
    Impedance.append(float(x))
    ap.AddMessage(x)
    ap.AddMessage(Impedance)
### School Network Service Area ###
# Create a network dataset layer and get hte desired travel mode
ap.nax.MakeNetworkDatasetLayer(nds,nd_layer_name)
nd_travel_modes = ap.nax.GetTravelModes(nd_layer_name)
travel_mode = nd_travel_modes[ap.GetParameterAsText(4)]
ap.AddMessage("Create network dataset")
# Instantiate a ServiceArea solver object
service_area = ap.nax.ServiceArea(nd_layer_name)
search_query=[['RoadsNetwork',"'STREET' IS NOT NULL And 'STREET' <> ''"]]
search_criteria=[['RoadsNetwork','SHAPE'],['NetworkDataSet_Junctions','NONE']]
search_tolerance = 500
# Set properties
service_area.distanceUnits = ap.nax.DistanceUnits.Meters
service_area.travelMode = travel_mode
service_area.outputType = ap.nax.ServiceAreaOutputType.Polygons
service_area.geometryAtOverlap = ap.nax.ServiceAreaOverlapGeometry.Overlap
service_area.searchQuery=search_query
service_area.searchTolerance=search_tolerance
service_area.searchToleranceUnits = ap.nax.DistanceUnits.Meters
service_area.polygonBufferDistanceUnits=ap.nax.DistanceUnits.Meters
service_area.polygonBufferDistance=50
service_area.polygonDetail=ap.nax.ServiceAreaPolygonDetail.High
for n in Impedance:
    ap.AddMessage(n)
    service_area.defaultImpedanceCutoffs = [n]
    fd = str(n)+'m'
    fm_fac = service_area.fieldMappings(ap.nax.ServiceAreaInputDataType.Facilities,True)
    fm_fac["Name"].mappedFieldName = 'PCODE'
    ap.AddMessage("Create a network Service Area {} network analysis layer".format(fd))
    # Load Inputs
    service_area.load(ap.nax.ServiceAreaInputDataType.Facilities, pc,field_mappings=fm_fac, append=False)
    ap.AddMessage("Facilities loaded!")
    # Solve the analysis
    result = service_area.solve()
    ap.AddMessage(result)
    expresult = os.path.join(Output_FD,"RoadNtwkBuf_"+fd)
    # Export Feature Class
    result.export(ap.nax.ServiceAreaOutputDataType.Polygons, expresult)
    for field in ap.ListFields(expresult):
        ap.AddMessage(field.name)
        if field.required == False:
            if field.name not in ['Name','ToBreak']:
                ap.management.DeleteField(expresult,'{}'.format(field.name))
    ap.management.AlterField(expresult,'Name','PCODE',clear_field_alias = "CLEAR_ALIAS")
    ap.management.AlterField(expresult,'ToBreak','BufferSize',clear_field_alias = "CLEAR_ALIAS")
    ap.management.CalculateField(expresult,'PCODE','!PCODE![0:6]')
    ap.AddMessage('Calculated service area for {}-m service area buffer'.format(n))
File "...\Scripts\01_NetworkBuffers.py", line 78, in <module>
RuntimeError
Failed to execute (NetworkBuffers).
Tags (3)
DavidPike
MVP Notable Contributor
hmm, how about changing the output location to just the GDB, possibly a mix of coordinate systems? What's with C:\Users\C:\Users\ for params 3 and 5?
Although you'd expect it to be the same as the input - and as you ay the tool does work a a standalone script.
I know you have the overwriteOutput set but still try making sure there's no locks/existing data etc. as part of the testing.
DavidPike
I don't see the full filepaths listed in the tool, looks more like they were dragged as layers - possibly try the full file path for GetParmeterAsText to work, or just as layers/datasets with GetParameter(n).  What data types do you have set?
I'd guess this is causing 'result' to be empty.
AndrewClark2
Thanks for the idea, but when printing out the parameters, they are all paths:
p(0): C:\Users\...\03_WorkingData\HEAL_ActiveLivingIndex
p(1): C:\Users\...\03_WorkingData\HEAL_ActiveLivingIndex\HEAL_ActiveLivingIndex.gdb
p(2): C:\Users\...\03_WorkingData\HEAL_ActiveLivingIndex\Scratch.gdb
p(3): C:\Users\C:\Users\...\03_WorkingData\HEAL_ActiveLivingIndex\HEAL_ActiveLivingIndex.gdb\RoadNetwork\NetworkDataSet
p(5): C:\UsersC:\Users\...\03_WorkingData\HEAL_ActiveLivingIndex\HEAL_ActiveLivingIndex.gdb\TESTPC
p(6): 400;800;1000
p(7): C:\Users\C:\Users\...\03_WorkingData\HEAL_ActiveLivingIndex\HEAL_ActiveLivingIndex.gdb\Analysis
I also get the following when printing out the result feature:
<arcgisscripting.ServiceAreaResult object at 0x00000223C8FBAD10>
So I believe the 'result' is not empty
DavidPike
AndrewClark2
You got it! Projection issue! Local dataset combined with a National dataset so mixing UTM Z17 with Lambert.... so annoying
DanPatterson
MVP Esteemed Contributor
parameter 4?
seems to be missing, or it is my eyes
... sort of retired...
