Convert multi KML and KMZ into shapefile using ArcPy?
5886
07-28-2015 12:23 AM
Yaron_YosefCohen
Hi everyone,
For clarity, i asked this question in python - Convert multi KML and KMZ into shapefile using ArcPy? - Geographic Information Systems Stac... .
I don't know how to do it with arcpy?
Thanks in advance.
DanPatterson_Retired
As Polygeo says, you have to add your filename variable to the folder since the first parameter is the kml filename, then the output folder...then optionally the output name NOT INCLUDING the folder name...and you can skip the last one.
KMLToLayer_conversion (in_kml_file, output_folder, {output_data}, {include_groundoverlay})
ParameterExplanationData Type
in_kml_file
The KML or KMZ file to translate.
File
output_folder
The destination folder for the file geodatabase and layer (.lyr) file.
Folder
output_data
(Optional)
The name of the output file geodatabase and layer file (.lyr). Defaults to the name of the input KML file.
String
(Optional)
Include ground overlay (raster, air photos, and so on). Use caution if the KMZ points to a service that serves raster imagery. The tool will attempt to translate the raster imagery at all available scales. This process could be lengthy and possibly overwhelm the service.
    <esri_enumhead><esri_enumvaluehd><esri_enumdeschd>
  • GROUNDOVERLAYGround overlays are included in the output.
  • NO_GROUNDOVERLAYGround overlays are not included in the output.  This is the default.
Boolean
Salehalamri
How we can write the code to help us to write script to convert multi format to another format
