convert graphic to feature in arcpy?
3704
02-25-2012 03:12 AM
lars1
apologies if this is easy but I cannot seem to find the answer. Is there a way to convert a graphic to feature, ie use the "Convert Graphics to Feature" tool on the toolbar, within arcpy?
I need to use a graphic as a selectbylayer feature, so either converting it or using the graphic directly would be nice.
Thanks!
JamesCrandall
Thanks!
Any solution to this?
ChrisSnyder
Honored Contributor
As far as I know, there is no way to do this in ArcPy.
However, there are ways to get a user-drawn feature (point, poly, line) as input to a tool. See: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002w00000023000000
