Conversion from CSV to DBF altering data...
13944
30
02-04-2016 01:19 PM
DannyLackey
So, I successfully converted my .csv to a .dbf with this script:
env.workspace = r"c:\Output"
inTable = r"c:\Output\test.csv"
outLocation = r"c:\Output"
outTable = "test.dbf"
arcpy.TableToTable_conversion(inTable, outLocation, outTable)
The problem is, in the resulting .dbf file, its adding a decimal with trailing zeroes to the value:
750050
becomes
750050.00000000000
How can I avoid this?
DannyLackey
Here is a sample of my data:
XYSTART_DTTMEND_DTTMValue
14680507501501/7/20161/31/20160.13237318
14681007501501/7/20161/31/2016-0.60834539
14681507501501/7/20161/31/2016-0.17450202
14682007501501/7/20161/31/2016-0.34773338
14677007501001/7/20161/31/2016-0.19723971
14677507501001/7/20161/31/20160.16580771
DarrenWiens2
Hmmm. That works for me. Can you get it to work properly through the GUI dialog? Do both X and Y come in as Long?
DannyLackey
You can get it to run programmatically as well?
XanderBakker
Esri Esteemed Contributor
It works for me (using your code), BUT you will need to use: Format=TabDelimited in your schema.ini is the file is delimited by Tabs.
DannyLackey
Well, my actual csv file is comma delimited.  The sample I posted here I opened in excel and copied and pasted a table-like structure.  Should it read Format=CommaDelimited?
XanderBakker
To avoid errors in the interpretation of the file it is best to attach the actual file instead of pasting it in a different format. The attach option is available (lower right corner) when you activate the advanced editor (link upper right corner).
DarrenWiens2
Yes, this results in exactly the same output table:
>>> inTable = r"c:\junk\Book3.csv"
... outLocation = r"c:\junk"
... outTable = "test.dbf"
... arcpy.TableToTable_conversion(inTable, outLocation, outTable)
If I change the csv to include a decimal (e.g. 750050.00001), then it gets read as Double, which will display decimal places.
Using the field map, I can force it back to Long (no more decimal places).
The code via Copy As Python Snippet changes to:
arcpy.TableToTable_conversion(in_rows="c:/junk/Book3.csv",out_path="c:/junk",out_name="test.dbf",where_clause="#",field_mapping="""X "X" true true false 4 Long 0 0 ,First,#,c:/junk/Book3.csv,X,-1,-1;Y "Y" true true false 8 Long 0 0 ,First,#,c:/junk/Book3.csv,Y,-1,-1;START_DTTM "START_DTTM" true true false 8 Date 0 0 ,First,#,c:/junk/Book3.csv,START_DTTM,-1,-1;END_DTTM "END_DTTM" true true false 8 Date 0 0 ,First,#,c:/junk/Book3.csv,END_DTTM,-1,-1;Value "Value" true true false 8 Double 0 0 ,First,#,c:/junk/Book3.csv,Value,-1,-1""",config_keyword="#")
DannyLackey
Did you run it with column names like: Col1=A Long or Col1=X Double  ?  Wondering what you may have done differently.
XanderBakker
This is my schema.ini
[test2.csv]
ColNameHeader=True
Format=TabDelimited
Col1=X Long
Col2=Y Long
Col3=START_DTTM DateTime
Col4=END_DTTM DateTime
Col5=Value Double
DannyLackey
SUCCESS!  I used the schema.ini example you just posted changing ONLY TabDelimited to CSVDelimited.  Thank you!
