Conversion from CSV to DBF altering data...
13780
30
02-04-2016 01:19 PM
DannyLackey
So, I successfully converted my .csv to a .dbf with this script:
env.workspace = r"c:\Output"
inTable = r"c:\Output\test.csv"
outLocation = r"c:\Output"
outTable = "test.dbf"
arcpy.TableToTable_conversion(inTable, outLocation, outTable)
The problem is, in the resulting .dbf file, its adding a decimal with trailing zeroes to the value:
750050
becomes
750050.00000000000
How can I avoid this?
XanderBakker
Esri Esteemed Contributor
This is my schema.ini
[test2.csv]
ColNameHeader=True
Format=TabDelimited
Col1=X Long
Col2=Y Long
Col3=START_DTTM DateTime
Col4=END_DTTM DateTime
Col5=Value Double
DarrenWiens2
I believe you'd have to use the Field Mapping parameter of TableToTable (which uses FieldMap and FieldMappings objects) to force the values into a field of LONG datatype.
Tip: set up the field mapping in the GUI tool, run it, then "Copy As Python Snippet" through the Results window to get the syntax correct.
XanderBakker
Not sure, but perhaps ArcGIS honors a schema.ini file: see Schema.ini File (Text File Driver)
ChrisSmith7
Honored Contributor
I can confirm, ArcGIS does indeed honor schema.ini files - I use these when working with flat files/CSVs to ensure data types (e.g. to keep leading zeroes, etc).
DannyLackey
Ok.  I have a schema.ini file.  Do I need to point the script to that file in some way or does it simply need to be present in the same directory as the script or output?
ChrisSmith7
Honored Contributor
Just make sure it's in the same directory - I create the schema.ini file in Python and write it to the directory where the table will go. So long as it's formatted correctly and in the same folder (you'll have to specify the target file in schema.ini), ArcGIS should pick-up on the driver to determine db structure. You can see this in action when viewing the tables in ArcCatalog.
DannyLackey
Ok.  My schema.ini file was created when I made a connection to my .csv file in Toad.  After looking at this file, I'm thinking it's not what I'm after.  Can you explain how you created your schema.ini file to suit your needs?
DannyLackey
Ok, I found this example here:  Does this method apply in my situation?  http://stackoverflow.com/questions/12259562/how-can-i-create-schema-ini-file-i-need-to-export-my-csv...
DanPatterson_Retired
and look athe link inside that link Importing CSV file into Database with Schema.ini - Creating Schema.ini file dynamically or at run-ti...
and the requirements in there
Points to remember before creating Schema.ini
1. The schema information file, must always named as 'schema.ini'.
2. The schema.ini file must be kept in the same directory where the CSV file exists.
3. The schema.ini file must be created before reading the CSV file.
4. The first line of the schema.ini, must the name of the CSV file, followed by the properties of the CSV file, and then the properties of the each column in the CSV file.
and it is a text file... so create in a text editor, and explore with different options until you get it right.  You can't foul up the csv file in any event... and even if that happened you would have your backup
DannyLackey
Something isn't working...
So, after having created the Schema.ini file containing this info:
[test.csv]
ColNameHeader=True
DateTimeFormat=dd-MMM-yyyy
Format=CSVDelimited
Col1=A Long
Col2=B Long
Col3=C DateTime
Col4=D DateTime
Col5=E Double
My conversion script is suddenly failing.  As soon as I remove this Schema.ini file, it runs fine.  Guessing there is something wrong with my Schema.ini file.  Is it clear where I went wrong?  It's in the same directory as the csv.
