Consume geoprocessing services as a REST service does not show data only structure (schema)
631
09-06-2024 01:33 PM
SanchezNuñez
Good afternoon
When I run this GPService directly in my browser  I get as a result  a json file with the structure (Schema)   and the data.  The service returns a feature polygon.
When I run this same GpService in Python as a REST service, I only get the structure or schema, not the data.
The code is pasted below:
# Requires Python 3+
import requests
import json
# Define the parameters for the geoprocessing task (here, a simple string-based task)
params = {
'ID': "98212", # Input ID as a string
'f': 'json' # Response format
URL = 'https://myserver/arcgis/rest/services/myfolder/myGpServer/GPServer/MyTask
# Send the request to the geoprocessing service
response = requests.post(URL, data=params)
# Check if the request was successful
if response.status_code == 200:
# Parse the response JSON
result = response.json()
print("Geoprocessing result:", json.dumps(result, indent=4))
# Extract the buffer geometry from the response (if available)
if 'geometries' in result:
buffer_geometry = result['geometries'][0]
print("\nExtracted Buffer Geometry:")
print(json.dumps(buffer_geometry, indent=4))
else:
print(f"Error: {response.status_code} - {response.text}")
