Conda package list for older versions of Pro?
1470
06-10-2022 10:16 AM
EvanThoms
Is there a place where the packages included in the conda distribution for each version of ArcGIS Pro are listed? I nearly always have the latest version of Pro and as I write tools against that I want to be able to provide documentation about the packages that won't be available at previous versions.
DanPatterson
MVP Esteemed Contributor
In short .... No.
These are the repositories where you might get some sense of the history
Package repository for esri :: Anaconda.org
esri-build :: Anaconda.org
... sort of retired...
DanPatterson
In short .... No.
EvanThoms
Thanks, Dan.
Yeah, I don't really know how to use that information. One module that I know is causing problems, in that it was not available for someone with 2.6, is lxml, which is not listed on either of those lists at all, so I don't know what to make of that. I looked around for some .yaml files for previous versions but only found one for 2.1.
Guess I will just have to rely on reports from users.
